Old 08-21-2020, 01:53 PM   #1
fred93
fred93's Avatar
Default Looking for seller of Penrite steering box lube
I am trying to find someone that sells the Penrite steering box lube in the US. All that I find is in Great Britain or Australia and they want outrageous shipping fees.
Please help!
Why is there never enough time to do it right, but always enough time to do it over!!!
fred93 is offline   Reply With Quote
Old 08-21-2020, 01:54 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Looking for seller of Penrite steering box lube
Please help!
https://restorationstuff.com/
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-21-2020, 02:00 PM   #3
1930-Pickup
Brent solved your problem.
I went the route of Penrite many years ago.
For my steering box, I now use a grease with a NLGI rating of 00.
00 rated grease just barely flows at room temperature.
You can buy it on-line (amazon), and tractor supply shops, and some auto parts shops.
Its much cheaper.
It doesn't leak out.
Its super easy to go straight from the bottle's pour spout into the steering box.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 08-21-2020, 05:52 PM   #4
fred93
fred93's Avatar
Thanks for the replies.
Old 08-21-2020, 08:13 PM   #5
Doug Linden
Doug Linden's Avatar
Ariens snowblowers use the same Semi-liquid grease (NGLI-00) for their auger gears. How ever anything from Ariens is a little expensive. I think the squeeze tube was $14.00.
Doug Linden is offline   Reply With Quote
Old 08-21-2020, 09:16 PM   #6
Cape Codder
Cape Codder's Avatar
I just read an article in the Model A News Tech Questions & Answers which talked about John Deere grease for "corn head" gear boxes. It was written that this grease is NGLI-0. What is the difference between the "corn Head" grease with the -0 and what is talked about above with the -00?
Cape Codder is offline   Reply With Quote
Old 08-21-2020, 09:46 PM   #7
steve smith
Not sure how many "0's" are involved but I have been using for years in my 6 ft rotary mower, my A's steering boxes and I mix 50% corn head with 50% stp for transmissions and diffs. They stock plenty at the local John Deere store. Comes in tubes like caulk, very easy to use. I think it was about 9 bucks a tube.
steve smith is offline   Reply With Quote
Old 08-21-2020, 10:17 PM   #8
1930-Pickup
NLGI 0 grease will flow, but it requires a higher temperature to do so. People use the JD corn grease for the Model A u-joint.
NLGI 00 grease will flow (barely) at room temperature. This makes it a good fit for the steering box. You can use the 0 grease in the steering box also, but its hard to get it in there, and to know when its filled.
Old 08-21-2020, 10:26 PM   #9
1930-Pickup
No "0"s are involved, because the standardized National Lubricating Grease Institute (NLGI) does not rate "home brewed mixes".
On a more serious note:
Only a few months ago, maybe late last year, the Deere Corn grease was not to be found anywhere. Prices went though the roof. I saw a single grease gun cartridge selling for over 40.00 on eBay (ePay). I'm not sure why the product just disappeared for several months, but who's to say it wont happen again. So stock up, or find alternatives.
Old 08-21-2020, 10:46 PM   #10
M2M
M2M's Avatar
Please help!
The Penrite is 00 grease, don't let them suck you into thinking their "lube" is anything specially made for vintage cars...that's just a marketing scam.
M2M is offline   Reply With Quote
Old 08-21-2020, 10:49 PM   #11
1930-Pickup
Exactly right
Old 08-21-2020, 10:53 PM   #12
1930-Pickup
For those who are unfamiliar with the NLGI rating system, here is where '00' grease fits in.
Old 08-21-2020, 10:59 PM   #13
updraught
updraught's Avatar
https://en.wikipedia.org/wiki/NLGI_consistency_number
So you are better off with cooking oil even if it leaks out?
"A true grease consists of an oil and/or other fluid lubricant that is mixed with a thickener, typically a soap, to form a solid or semisolid. Greases are a type of shear-thinning or pseudo-plastic fluid, which means that the viscosity of the fluid is reduced under shear. After sufficient force to shear the grease has been applied, the viscosity drops and approaches that of the base lubricant, such as the mineral oil."
https://en.wikipedia.org/wiki/Grease_(lubricant)
updraught is offline   Reply With Quote
Old 08-21-2020, 11:04 PM   #14
alexiskai
alexiskai's Avatar
The Tractor Supply 00 grease being discussed is this one here. More discussion and pictures in this thread.
alexiskai is online now   Reply With Quote
Old 08-21-2020, 11:55 PM   #15
M2M
M2M's Avatar
Your mates at Australian owned Penrite suggest using it. They even put a fancy drawing of an old car on their 00 grease which they call "lube" to make you feel better about your purchase.
Old 08-22-2020, 03:37 AM   #16
updraught
updraught's Avatar
So what's the problem with it?
Or is the grammar not up to scratch?
Old 08-22-2020, 06:38 AM   #17
1931 flamingo
1931 flamingo's Avatar
Regardless of the graphics or supplier, IT WORKS.
Paul in CT
Old 08-22-2020, 06:46 AM   #18
old31
I am using regular red grease on my torque tube and grease fittings.
Do you think Penrite would be better for the torque tube?
old31 is offline   Reply With Quote
Old 08-22-2020, 03:18 PM   #19
McMimmcs
Paul in CT
Common sense prevails. Who cares about the graphics if it works! Besides that I like the old car photo !
Old 08-22-2020, 05:23 PM   #20
M2M
M2M's Avatar
Product is good BUT it is overpriced and they are marketing it as a "lube" to suck people into thinking it's a specifically made product for vintage cars. It's 00 grease nothing special to warrant the price they ask.
Paul in CT
Of course it works, it's 00 grease. Go to a Tractor Supply store and buy it there. Why buy imported Australian grease? Because of the picture? Or are USA manufacturers too corrupt or stupid to produce a quality grease? Anyone in the USA buying this must have very little faith in their own country.
Paying a high end price for imported grease is NOT common sense. That sounds like a sucker to me. BUY MADE IN USA!
