Old 10-06-2019, 05:05 PM   #1
fredski53
fredski53's Avatar
Default Transmission dipstick kit
Is anyone using a dipstick kit to check level of oil in the trans?
fredski53 is offline   Reply With Quote
Old 10-06-2019, 05:15 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Transmission dipstick kit
Nope, not me.
Old 10-06-2019, 06:41 PM   #3
Mike85212
Mike85212's Avatar
The Coupe that I just bought had one in already.
Mike
Mike85212 is offline   Reply With Quote
Old 10-06-2019, 06:45 PM   #4
rfitzpatrick
YES!! Love it too
rfitzpatrick is offline   Reply With Quote
Old 10-06-2019, 08:47 PM   #5
ArtimusGordon
I put one on my coupe. Purchased from Mitchel OD/trans mfg. I’m 82 and limit my time under the A if possible. Cut a hole in the floor board and pull the carpet back to access the dip stick. YEA, no more back pain! 👍 😊
ArtimusGordon is offline   Reply With Quote
Old 10-06-2019, 10:40 PM   #6
w.michael
w.michael's Avatar
The transmission dip stick makes the level easy to check, but not so easy to correct. I had to try several funnels to get the right shape/size to use to fit through the floor board and to fill through the tube; and then you have to add a little at a time and recheck with the dip stick several times to know if you have added enough or too much. You have to replace the cap each time in order to use the dip stick and get a correct reading.
But it is still easier than crawling/squeezing under the car in the dirt, and lying on your back with oil dripping down you wrists and into your face.
W. Michael
w.michael is offline   Reply With Quote
Old 10-07-2019, 07:09 AM   #7
Steves46
Steves46's Avatar
I am and really like it. Easy to install.
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 10-07-2019, 10:10 AM   #8
30 Closed Cab PU
I have one, use for same reasons as post 5, back issues.
I also installed the Battery access kit so I do not have to remove the entire lower floor board to remove/install/service the battery.
Type in Macs parts, search for battery kit. Tried to include a link, but keeps going to a Ecklers Corvette parts page.
Last edited by 30 Closed Cab PU; 10-07-2019 at 10:26 AM. Reason: link did not work
Old 10-07-2019, 10:14 AM   #9
30 Closed Cab PU
Only downside, would be nice if they made a trans kit where the tube/dip stick stuck above the floor. Then there would be no need to pull the floor covering and access plate up.
Old 10-08-2019, 10:34 AM   #10
Bob Bidonde
Bob Bidonde's Avatar
My solution to ease access to the transmission fill plug.
Bob Bidonde
Old 10-08-2019, 01:49 PM   #11
California Travieso
Send a message via Yahoo to California Travieso
Hey Bob,
I like your gearshift nob. It looks like it's an antique door knob. I grew up in the '40's and '50's in a house that was built in the late 1890's or early 1900's. All our doors had that type of door nobs.
David Serrano
California Travieso is offline   Reply With Quote
Old 10-08-2019, 02:20 PM   #12
Werner
Werner's Avatar
Hi Fred, yes I have it since 9 month. It is a good idea. I would buy it again.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
