09-23-2019, 09:23 PM | #1 |
Anyone have a battery cap?
Hey folks! Very much a newbie here. I have a '29 Tudor with a Napa Commercial 7244 battery with a missing cap. I am trouble finding anyone who carries a replacement cap. Anyone have an idea of where I could find one? Thanks!
09-23-2019, 10:21 PM | #2 |
Re: Anyone have a battery cap?
I have several old batteries laying about but distance would make me sending you one unfeasable. A photo would help others wanting to help.
09-24-2019, 05:11 AM | #3 |
Find a NAPA or other user friendly parts store. Usually they have a half ton of trade-in batteries to browse for caps.
Also most scrap metal places take batteries..... Good luck
'30 Coupe |
09-24-2019, 06:48 AM | #4 |
Thanks. I tried Napa immediately (since it's Napa battery)..no go there. But I'll ask around.
09-24-2019, 10:42 AM | #5 |
Go to a junkyard that recycles old batteries. They should have lots!!
09-24-2019, 03:25 PM | #6 |
09-24-2019, 06:20 PM | #7 |
So long as they fit, just find 3 the same from some other battery and screw them in. Done!
09-24-2019, 06:52 PM | #8 |
I used a large rubber stopper from the local hardware store for years on my 6 volt battery. I even used a very small diameter plastic tube (from a carb cleaner spray can) for venting. A small V shaped cut on the side of the rubber stopper was added for the vent tube.
Bob-A Skirts are for women not car fenders! |
09-24-2019, 10:04 PM | #9 |
Six and eight volt batteries use larger caps than the common twelve volt battery and always have as best as I remember . Good luck finding a cap or caps .
09-25-2019, 04:50 PM | #10 |
Can you post a picture with a ruler nearby, is it push on or screw on--- if screw on is it 1/4 turn or threads--- pictures of cap and battery
09-25-2019, 08:37 PM | #11 |
Looks like it is 1.25" in diameter at the top. It is a push-on, and the opening is 3/4". Any ideas would be awesome!
I can't get the pictures to load from a dropbox link. Last edited by zaugger; 09-25-2019 at 08:39 PM. Reason: Pictures not showing up. |
09-25-2019, 08:40 PM | #12 |
Sorry guys...clearly messing up this thread with my newbie posting skills. I cannot add pictures, but I'll try to find the correct way to upload them.
09-25-2019, 08:41 PM | #13 |
[QUOTE=Bob-A;1802761]I used a large rubber stopper from the local hardware store for years on my 6 volt battery. I even used a very small diameter plastic tube (from a carb cleaner spray can) for venting. A small V shaped cut on the side of the rubber stopper was added for the vent tube.
Bob-A Now THAT'S an interesting solution. Thanks for sharing! Chris |
09-25-2019, 10:09 PM | #14 |
09-26-2019, 01:30 AM | #15 |
I have an old battery in my garage. I can look at the caps and put a couple in the mail to you if I have your address.
09-26-2019, 07:04 AM | #16 |
09-26-2019, 01:22 PM | #17 |
Google could be your friend??
Paul in CT |
09-26-2019, 10:38 PM | #18 |
09-27-2019, 12:36 PM | #19 |
I just went on ebaymotors, parts and acc, 6volt battery bcaps and a couple of possibilities came up. FWIW
Paul in CT |
