03-18-2016, 01:08 AM | #1 |
239 flathead head gaskets
Hello I am replacing the head gaskets on my flathead , and I would I would like to know about cleaning the block what sort of sand paper could I use to not scratch the block..
Thanks |
03-18-2016, 01:21 AM | #2 |
Re: 239 flathead head gaskets
You should not use sandpaper to prepare the block or heads for new head gaskets. You don't want to get any grit into the cylinder bores....
03-18-2016, 01:29 AM | #3 |
Ok so what do you recommend to cleaning off carbon on the block
03-18-2016, 01:33 AM | #4 |
use a good carb. clener
03-18-2016, 01:37 AM | #5 |
Ok so try and soak it with carb cleaner then
Wipe down |
03-18-2016, 03:01 AM | #6 |
03-18-2016, 11:05 AM | #7 |
Ok I'm gonna try and see what I can do
03-18-2016, 11:32 AM | #8 |
03-18-2016, 11:53 AM | #9 |
I think you will find the scraper posted by Bob C to work very well. I have used it on my engine. No damage.
03-18-2016, 04:09 PM | #10 |
Oven cleaner and razor blades.
Lonnie |
03-19-2016, 12:21 PM | #11 |
Use a long handle razor blade scraper,
it saves wear and tear on the knuckles and fingers! http://www.nationaltoolwarehouse.com...FdgcgQodagoDnw |
