Old 08-16-2021, 07:58 PM   #1
Shampipple
Shampipple's Avatar
Default 39 Pickup Cab Floor
I’m still gathering items for this winters build. I found the kick panel/pedal board piece. I have wood for the under foot area, as I believe the original was.
I’m looking for a photo of the trans tunnel/hump/cover.
I’ve seen conflicting designs out there. Most trucks have a mat or carpet, and I just want a decent example to go from.
If someone would please share a photo of the floor/tunnel area I would really be grateful.
If someone has one for sale I’d be even more grateful!
Thanks in advance.
29 Model A Roadster, 39 Pickup, 50 Custom Tudor, 66 Mustang Fastback, 79 F350, 02 Thunderbird
Shampipple is offline   Reply With Quote
Old 08-17-2021, 01:06 PM   #2
1939mars
1939mars's Avatar
Default Re: 39 Pickup Cab Floor
I think this picture is of an original mat but I do not know for sure. I am pretty sure that the rubber cover should not be over the shift tower. Below is a mat that is being reproduced but you have to cut your own holes. When I made mine I just used rubber floor mat stock and think it turned out pretty nice. Kind of beat up now though...
https://www.dennis-carpenter.com/tru...UaApJdEALw_wcB
1939mars is offline   Reply With Quote
Old 08-17-2021, 01:18 PM   #3
1939mars
1939mars's Avatar
A pic of my mat
Old 08-17-2021, 02:06 PM   #4
Kube
Kube's Avatar
This is a '40 but I'm quite certain the '39 mat is identical. This, if it matters, is concourse correct.
Old 08-17-2021, 05:04 PM   #5
mercman from oz
mercman from oz's Avatar
Interior of 1940 Ford Pick-Up showing Floor Mat.
Old 08-17-2021, 07:25 PM   #6
Shampipple
Shampipple's Avatar
The Mats help a lot. I appreciate the photos.
I should have specified the metal hump itself is what I’m after.
I have the toe panel section and the floor board. Just no trans hump or the firewall cover.
Old 08-17-2021, 07:48 PM   #7
Kube
Kube's Avatar
Does this help?
Old 08-17-2021, 08:19 PM   #8
Shampipple
Shampipple's Avatar
Yes indeed! Thank you!
Where did you get the metal floor pans? I have wood!
Old 08-17-2021, 09:09 PM   #9
Tinker
Tinker's Avatar
On a 38 they would have been wood, believe 39 too. That is pictures from kube (mikes) 40 truck build that people share.
I can take a picture of the part you are asking about, but I would have to pull my matte out. I'll look if I have a before picture. The trans cover is really squareish. Not very rounded on the the outer lip.
Old 08-17-2021, 09:21 PM   #10
Kube
Kube's Avatar
The photos I've posted are of a '40 I'd restored. I think, but do not know for certain, that '39 was identical to my '40. I'm hoping a '39 expert will weigh in here.
Old 08-17-2021, 09:30 PM   #11
Shampipple
Shampipple's Avatar
Thank you both. I’m just trying to find the correct type cover the first time.
I may put 40 floors in it. Those look great!
Old 08-17-2021, 10:19 PM   #12
Tinker
Tinker's Avatar
I'm not an expert. But 39s had wood floors. Not saying you can't make a metal one.
It's the same thing with the roof on the 37. Ford was able to punch out sheet metal roofs in one piece. No need to do them in two parts and use a wood insert. Trucks were always the last to get anything new. Luckily they had short roofs.
https://www.earlyfordv8.org/forum/pr...m=18&Topic=440
Old 08-17-2021, 11:33 PM   #13
1939mars
1939mars's Avatar
Here are a few pics of the floorboards and transmission cover from my '39 parts pickup. My driver has a plywood replacement for the wood so it would only be useful for a pattern. The metal transmission cover is the same for '38 & 39 but the '38's had an extra hole that the parking brake went through. For '39 The hole has a patch tack welded in or it is a knockout. Never been able to tell which. I have seen may like that so am pretty sure its original.
Old 08-17-2021, 11:39 PM   #14
Tinker
Tinker's Avatar
Great pictures. I replaced mine with 5/8 cabinet plywood. Thank you. I will save this.
38 trucks didn't have a parking break lever like the 36 cars or others. it had a dash mounted lever like a 39. The hole might have been present though.
Old 08-18-2021, 07:18 AM   #15
Kube
Kube's Avatar
Thanks for clearing this up for me Mars.
Old 08-18-2021, 03:33 PM   #16
1939mars
1939mars's Avatar
I have seen a '38 pickup with the dash mounted brake lever, but Mack Hil's book also shows them on the floor. My guess is that it was a running change from floor mount to dash mount at some point in the production year.
Old 08-19-2021, 01:15 AM   #17
Shampipple
Shampipple's Avatar
Thank you! 39Mars- are you willing to sell that trans cover?
Old 08-19-2021, 09:37 AM   #18
38bill
38bill's Avatar
The "Big" trucks had a floor mounted E brake, the 1/2T's brake lever is mounted under the dash. The trans covers are hard to come by as the were under the floor mat and subject to rust. I see that Third Gen Auto carries repops.
38bill is offline   Reply With Quote
Old 08-19-2021, 10:49 AM   #19
1939mars
1939mars's Avatar
Sorry, nope. It is doing its job in my pickup as we 'speak.'
Old 08-19-2021, 10:14 PM   #20
Tinker
Tinker's Avatar
I'm not sure I did. But thanks kube.
