Old 11-18-2018, 07:00 PM   #21
Gary WA
Gary WA's Avatar
Default Re: Growling noise when clutch is engaged
Originally Posted by ghalperin View Post
That turned out to be the problem. I guess after my last 100 mile drive, my crankshaft endplay increased. I had one long starter bolt and it was hitting the flywheel. I guess that after swapping out the TO bearing, I put the long bolt back in the same place. I measured the end play today, .030. Too much. It still runs fine and no growling noise.
I’ll start a new thread on fixing the crankshaft end play.
The pressure plate was way out of adjustment as well, at least I have another thing corrected.
Thanks for everybody’s help.
Thanks for the update! Enjoy the Ride and satisfaction of problem solving! Have a Great Thanksgiving! Now Drive On!!
www.whidbeymodelaclub.com
Old 11-18-2018, 11:21 PM   #22
Tom Wesenberg
Tom Wesenberg's Avatar
All 3 starter bolts should be 1" long.
I wouldn't worry about the .030" freeplay unless it's causing a problem such as lots of oil loss. The freeplay can be fixed when the engine has a more serious problem. My engine had more freeplay than that, and no problems due to freeplay.
