Old 07-25-2018, 01:27 PM   #1
braol
braol's Avatar
Default Windshield Blocked by Gascap...
Should the windshield open all the way without contacting the fuel cap?
If I remove the cap I can open the window the rest of the way. Perhaps I have a non-OEM item. I just learned that the gasket of the original should be leather, but I don't remember what mine has.
"I have not yet begun to defile myself."
-Doc Holliday
'31 Tudor, '69 F100, '66 Mustang, '11 Ford Flex
braol is offline   Reply With Quote
Old 07-25-2018, 01:29 PM   #2
Tacoma Bob
Tacoma Bob's Avatar
Default Re: Windshield Blocked by Gascap...
Yup. Sounds like your header over the windshield is going bad. You might get lucky and be able to tighten up the windshield upper frame screws.
Tacoma Bob is offline   Reply With Quote
Old 07-25-2018, 01:31 PM   #3
Will N
Will N's Avatar
Might be your header, but some of the repro gas caps are too high.
Will N is offline   Reply With Quote
Old 07-25-2018, 02:35 PM   #4
figment
I had a reproduction gas cap that would not let the windshield move past the cap because it sat to high . I put a original on and the clearance was just right . I had all new header and everything was fitting right except the repo gas cap .
figment is offline   Reply With Quote
Old 07-25-2018, 03:09 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
I looked at a coupe with the problem ,compared it to mine and the reproduction header wasn't cut the same as original and put the hinge area too low,
Old 07-26-2018, 07:00 AM   #6
desotoguy
Repo windshield hinge rubber gasket can cause an ill fitting windshield.
desotoguy is offline   Reply With Quote
Old 07-26-2018, 09:29 AM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
On Minerva, my '30 Coupe, the window JUST cleared the cap & I could sit in the Pilots' Seat & gas her up!---Got lots of "LOOKS"---
Bill Attendant
"THE ASSISTANT GURU OF STUFF"
Old 07-26-2018, 11:31 AM   #8
braol
braol's Avatar
My cap has a cork gasket and not leather. I may try a more vintage style cap to see what happens.
I was going to get a tank filler screen but I can't tell if I should get the threaded one or the one with the tabs.
-Doc Holliday
Old 07-26-2018, 01:34 PM   #9
Badpuppy
My gas cap is about 3/4" tall and the windshield clears just fine.
Early tanks used a threaded screen (flame arrester) but changed to tabs, then went back to threads, not sure of the exact timeline. Inside the neck of my '30 tank are two slots stamped near the opening for two of the tabs to twist into. Otherwise feel around for a thread groove.
I got one that just drops in, but it rocks side to side. I might cut tabs on the top to hold it in place.
Badpuppy is offline   Reply With Quote
