08-14-2015, 02:54 AM | #1 |
Starting problem fixed
I have been chasing a slow starting problem in my 33 with the 99a engine in for a while.
It always starts ,but the starter seemed to have one big job to spin the motor, Well today ,at a loose end, I thought I would take the generator off to fix a squeak in it, On stripping the generator I saw a black segment on the commentator,and one wire gone from it through the steel part. I fitted a NOS armature,first thing,I had to back the third brush way back to get the charging down,After mucking around setting the third brush,I noticed it started like a rocket, Not slow turning over like before, My thoughts are,even though it always showed a charge on the amp meter it may only have been putting in less that the 6v. |
08-14-2015, 05:53 AM | #2 |
Re: Starting problem fixed
Buy optima red top battery
Thanks - 30-9 1939, 1940 |
08-14-2015, 07:31 AM | #3 |
He's fixed the problem, it wasn't a battery fault, it was charging fault. "it now started like a rocket"
Did you actually read the post? Martin. |
08-14-2015, 07:44 AM | #4 |
Sorry mis-read need more coffee
08-14-2015, 01:57 PM | #5 |
Classy response.
08-14-2015, 02:36 PM | #6 |
