Old 09-29-2015, 06:58 PM   #1
RKS.PA
RKS.PA's Avatar
Smile 1947 Convertible Hydraulic Fluid Used?
I'm rebuilding the top pump in my '47 convertible. The old stuff looks like battery acid and it's in the pump motor armature etc. I'm in the process of cleaning it out and ordering a pump and motor rebuild kit from Mac's.
What type of fluid should I put in after the overhaul?
Thanks very much!
Dick.
RKS.PA is offline   Reply With Quote
Old 09-29-2015, 07:09 PM   #2
Bruce in southern OH
Bruce in southern OH's Avatar
Default Re: 1947 Convertible Hydraulic Fluid Used?
Richard, try this site:
http://www.fordsunlimited.com/fords_convertible.html
Lots of additional info, Bruce
Fluid Level
1. Remove the rear seat and raise the top.
2. Place absorbent cloths below the filler plug.
3. Remove the filler plug, and check the fluid level. It should be level with the bottom edge of the hole.
4. If the level is low, check the system for leaks, adding automatic transmission fluid - Type A, Suffix A - as necessary.
Last edited by Bruce in southern OH; 09-29-2015 at 07:42 PM. Reason: Addition info
Bruce in southern OH is offline   Reply With Quote
Old 09-29-2015, 07:32 PM   #3
Ford46
Ford46's Avatar
RKS.PA, originally brake fluid was used (you can see what a mess that makes, imagine if some leaked and what it did to the paint!). Some people use ATF fluid in the pumps and cylinders now. I'm sure Hydro-Electric in Florida has information on their web site. LouB.
Ford46 is offline   Reply With Quote
Old 09-29-2015, 07:33 PM   #4
paul2748
paul2748's Avatar
Use Type F trans fluid. That is what I use in my 48 Conv. Been using it for 25 + years with no problems.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-30-2015, 07:46 AM   #5
RKS.PA
RKS.PA's Avatar
Thanks guys, Bruce, I printed off the material on fordsunlimited. and Ford46, looks like Hydro-Electric...must be around the corner from Skip Haney....has everything I may need. Good info, Paul, on the Type F ATF. Think my system was brake fluid. Will do a complete flush and go with ATF.
Dick.
Old 09-30-2015, 08:00 AM   #6
Vic Piano
Vic Piano's Avatar
OEM was brake fluid. I replaced it with ATF. ATF does not hold moisture and is much more forgiving if it gets on paint.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 09-30-2015, 09:13 AM   #7
RKS.PA
RKS.PA's Avatar
Thanks, Vic. Anything I should know about purging the system before adding the ATF? Also, did you use Type F per Paul 2748? Guessing the Type has to do the lines and seals?
Dick.
Old 09-30-2015, 10:20 AM   #8
Mike51Merc
Mike51Merc's Avatar
It looks like battery acid? The last time I looked, battery acid looks like water.
Type A trans fluid was used for years, but that was whale oil based and not around anymore. I substituted some Dex/Merc a few years ago which works fine for me.
Mike51Merc is offline   Reply With Quote
Old 09-30-2015, 10:22 AM   #9
Vic Piano
Vic Piano's Avatar
I used ATF I had on the shelf, don't remember if it was Type F. I've had it in my '47 Convertible for almost 10 years with no leaks.
Old 09-30-2015, 11:43 AM   #10
RKS.PA
RKS.PA's Avatar
Mike, I should have said the stuff inside my pump and motor looked like battery corrosion around the terminals.....nasty looking and it shorted out the pump motor armature. Guess that's what happens to 68 year old "brake fluid" when it oxidizes!!
Thanks for the reply.....Dick.
Old 09-30-2015, 11:48 AM   #11
flatheadmurre
flatheadmurre's Avatar
Today the new silicon brakefluid could be an option to.
Old 09-30-2015, 12:20 PM   #12
rotorwrench
rotorwrench's Avatar
Brake fluid has to meet some very extreme specifications but a hydraulic top lift mechanism doesn't. Type A trans fluid was replaced by type F some years ago and some suppliers refer to it as type F/A so that you can tell it meets both specs. Type F is close to MIL-H-5606 which is a straight mineral hydraulic oil that is still used in older aircraft systems but it has a few more additives. Both are red in color too. These hydraulic fluids won't strip your paint like brake fluid will.
Old 09-30-2015, 01:06 PM   #13
flatheadmurre
Just about any ATF will do as hydraulic fluid.
The differences in types has more to do with temprange and frictionmaterial wont make any difference in this case.
And if the seals cant handle the oil its gonna go bad with any type.
Old 09-30-2015, 03:05 PM   #14
V12Bill
V12Bill's Avatar
Bought some top hydraulic rams from Hydro Electric several years ago and they said NOT to use Silicon brake fluid or the guarantee was void. Use only ATF. Since type a or F is no longer available, use what they sell for
ATF. Have used ATF in'64 Lincoln Conv and 48 Zephyr convertible for many years with no negative results.
V12Bill is offline   Reply With Quote
Old 09-30-2015, 03:46 PM   #15
Sounds great Dick, Fordbarn to the rescue as always, like your Avatar!!!!!
