05-29-2014, 05:54 AM | #1 |
A question for the Pilot owners
G'Day fellas,
What is the length of the dip stick please ?. A mate has lost his and I have found one that has different markings,just Full and Low on a brass tag which is riveted on to the stick, and measures 16" long. Hoping that someone may be able to help . Thanks in advance, Regards,Gary |
05-29-2014, 01:36 PM | #2 |
Re: A question for the Pilot owners
Mine is 16 inches to where it seats at the tube.
05-29-2014, 03:05 PM | #3 |
The dipstick you describe sounds like a Pilot version...bear in mind the tube on a Pilot is correspondingly longer too.
05-29-2014, 05:31 PM | #4 |
For peace of mind it's probably worth doing it from first principles. Put a known amount of oil in (that you would be happy to run with) insert a dipstick. Make a mark where the oil comes up to. Always replenish to that mark.
Unless you are in control of dipstick type and tube length you could always come a cropper. My 21 stud had that problem. When I investigated, I found the real oil level needed to be 3/4" above the max mark on the stick I was using. Mart. |
05-29-2014, 05:32 PM | #5 |
Mike B and Brian,
BINGO !!.Thanks for the replies. I was hoping that it was the correct one. I knew that it was a Ford one because there is nothing in my shed from the darkside. |
05-29-2014, 05:59 PM | #6 |
Thread Tools | |
Display Modes | |
