04-13-2018, 05:06 PM | #1 |
Spark Plugs
I know that the Champion 2 COM-l will fit a Model A, But does anyone know just what that plug was made for & listed as such..
04-13-2018, 05:43 PM | #2 |
Re: Spark Plugs
I believe plug was designed for use in early tractors. W18 is replacement. Enjoy.
04-14-2018, 08:43 AM | #3 |
Re: Spark Plugs
For those who may be interested, the following 7/8"-18 spark plugs will fit the Model A and were available as of a few years back. They are also not all the ones that I know of.
Champion (hotter down to colder): W95D W89D W16Y W20 W18 W14 W10 W85N W80N Also the original 3X and W18 which Champion lists as norm. Also according to Champion, the W16Y is hotter than the W18 at low speed but cooler at high speeds over 5500 RPM....(over 5500 RPM? ... maybe Speedy ED J, Pete, George Miller, Dennis Pierce would be interested... maybe even Brent) Motorcraft (hotter down to colder): TT15 (the same as Champion W89D) TT10 (the same as Champion W14) TT8 (the same as Champion W14) TT4 (the same as Champion W10) Autolite: 3076 (the same as Champion W14 and Motorcraft TT10) Mopar (hotter down to colder): P-9-7S P-9-6S P-9-5S Prestolite (hotter down to colder) 78-10 78-8 Stitt (hotter down to colder) 137 BSP 197 147 B 13/10 Range is a key word when one speaks of heat range. Reading these Champion numbers is not real difficult. For example, W20 or W18, etc.: The W is the shell design and it always means 7/8-18. I should also add that Champion has made changes over time. For example a C-16C, used in many a Model A, starts with a C, BUT it is a 7/8-18 plug. It was discontinued about 1979 and replaced by the W16Y. There are many like this. The number is the heat range and the lower the cooler (unless other letters immediately follow, like Y for example, which depending on the letter or letters can change or affect the heat range): 1- 25 = Automotive and small engines 25 - 50 = Aviation 51 - 75 = High Performance 75 - 99 = Industrial and Special Applications by Larry Brumfield
04-14-2018, 09:06 AM | #4 |
Re: Spark Plugs
Vermin had C-16-Cs, also fit Old Packards. They were BRAND NEW!
Think back about all the MIRACLE Spark Plugs that have come & GONE! The S.E. Fire Injectors were notorious for ejecting their long center electrode & IMPALING it into a PISTON!!! Bill Seenalot
04-14-2018, 01:16 PM | #5 |
Re: Spark Plugs
Note that Champion seems to be changing their numbers, for example a 3X is now listed as 429, W16Y as 561, etc.
04-14-2018, 02:07 PM | #6 |
Re: Spark Plugs
etc., etc. Bob-A |
Thread Tools | |
Display Modes | |
