Old 09-26-2021, 08:56 AM   #1
Randy Lausch
Default Valves
Some of my exhaust valves are running .012 do you think that is close enough or shouldI have the valve stems ground down. If I need to what kind of grinder can I buy to do that
Randy Lausch is offline   Reply With Quote
Old 09-26-2021, 09:10 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Valves
.010" on intakes isn't too bad, could stand to be a bit looser though.
.20" on the exhaust is crazy loose ! Grinding the stems won't help. There is something drastically wrong like bad camshaft, bad lifters. Unless .20" is just a misprint.
Grinding the stem loosens things more.
I'm assuming the lifters are original style.
Old 09-26-2021, 11:07 AM   #3
Jim Brierley
Default Re: Valves
.010" on the intakes is a bit tight but won't cause any damage because they run cooler than exhausts.
Jim Brierley is offline   Reply With Quote
Old 09-26-2021, 01:06 PM   #4
700rpm
700rpm's Avatar
Default Re: Valves
My engine rebuilder (Gordon Fischer) suggested for show car i: .011 e: .013
For Driver: i: .010 e: .015
Ray Horton, Portland, OR
