03-21-2021, 05:44 PM | #1 |
1934 ford front fender tie
I took this car apart 25 years ago, The older I get the less I remember some things. Other things I can go back and remember 60 years ago at least I THINK i can. MY QUESTION IS ON THE FRONT FENDER TIE ON A 34 FORD. i do not remember what the small slot headed screw is for does anyone know. The area it is in is recessed. Thanks for any help. Stan
03-21-2021, 06:17 PM | #2 |
Re: 1934 ford front fender tie
To retain the retain front fender welting which ran back to the firewall on each side.
03-21-2021, 09:41 PM | #3 |
Thank you David G, Then it will require a large diameter flat washer. Right now it just has a small lock washer. Thanks for your reply. That makes sense. The fender welting runs all the way back to the running boards. Thanks again. Stan
03-21-2021, 10:05 PM | #4 |
