09-08-2019, 08:40 PM | #1 |
Unfilling a 1932 Ford Grille
I picked up a really nice grille shell for my '32 project. Only, it's been filled and I need an unfilled shell. Can I buy the piece to fix it? If so, where?
Thanks! |
09-08-2019, 09:01 PM | #2 |
Re: Unfilling a 1932 Ford Grille
Sent you a PM
09-08-2019, 10:41 PM | #3 |
I bet you would be better off swapping for one with an opening. Try a wanted ad.
Charlie Stephens |
09-08-2019, 11:58 PM | #4 |
you can just drill the screw holes for the trim and cap & bolt them on over the filler part. i've done it - easy!
09-09-2019, 12:04 AM | #5 |
oops' unless you want to use it to fill the radiator- on mine, i still used the add on filler on the back of the radiator.
09-09-2019, 12:26 AM | #6 |
09-09-2019, 12:53 AM | #7 |
There is more than just drilling the hole on top unless they just filled the hole. Many end up reshaping the top of the shell before filling.
Vic |
09-09-2019, 10:57 AM | #8 |
I checked my stash and must have sold the piece I cut out of a Vintique stock style shell to fill it. Sorry. Try running an ad on the HAMB for that top piece.
09-09-2019, 06:23 PM | #9 |
Thanks for the input. Stock, unfilled units just don't seem to pop up that often around here. I'll try for a trade then graft if that won't work. Thanks.
