Old 06-29-2015, 03:55 PM   #1
40cpe
40cpe's Avatar
Default 306 Cu In
There is a thread on the HAMB about Vern Tardel building an AV8 with a 306 in flathead. What is the bore/stroke of a 306? What is the largest cube possible flathead with water jackets?
http://www.jalopyjournal.com/forum/t...973427/page-12
You will have to scroll down till you see the video.
40cpe is offline   Reply With Quote
Old 06-29-2015, 04:02 PM   #2
KiWinUS
KiWinUS's Avatar
Default Re: 306 Cu In
Gene I am guessing Verns engine is 3 3/8 bore x 4 1/4 stroke ? I have not read the article . I have 2 engines with this combo.
Cheers
Tony
KiWinUS is online now   Reply With Quote
Old 06-29-2015, 04:08 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
3-3/8 X 4-1/4 does work out to 304+ inches. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-29-2015, 04:10 PM   #4
my4dv8
So tony , tell us more please. How do they perform?
There is one out in nz , well that's what is signed on the door (306 or 304)but it doesn't seem to really haul at the nostalgia drags , kind of sounds flat . No pun intended.
Do these rev well . The low end torque should give a real kick.
We are planning a 3 5/16 by 4 1/4 stroke with a kiwi L 100 cam.
my4dv8 is offline   Reply With Quote
Old 06-29-2015, 05:00 PM   #5
40cpe
40cpe's Avatar
I found a site to calculate volume. It works out to 3.375" plus .010" puts it right on 306".
Old 06-29-2015, 05:24 PM   #6
Pete
Pete's Avatar
"What is the largest cube possible flathead with water jackets?"
I built one with 345 ci. It is possible to go slightly more.
I have built several in the 320 to 325 range.
Old 06-29-2015, 05:30 PM   #7
KiWinUS
KiWinUS's Avatar
Pete great stuff ... what were the bore stroke combo's & what rods & other mods were required ?
Old 06-29-2015, 06:01 PM   #8
Pete
Pete's Avatar
Bore was 3.405.
Stroke was 4.750.
New 21A rods, shotpeened, reconditioned and bored to length. Matched set so it took a very minimum to balance.
Lots of grinding in the block.
The engine was very hard on rings because of the short skirt pistons and lots of clearance.
This was one engine I was later very sorry I built.
Although it was a winner, the customer told me it was for the drags but he put it in a circle track roadster running under a 300 cubic inch rule. They caught it and took all his points and fined him but it really pissed me off.
Old 06-29-2015, 10:19 PM   #9
Ol' Ron
Ol' Ron's Avatar
Dick Kacalis runs a 345 ci in his dragster, engine has been running the 1/4 mile for the past 15 years.
Old 07-01-2015, 08:15 AM   #10
flatheadrunners
Keith Tardel built the motor. It was are backup motor for our Bonneville car.
flatheadrunners is offline   Reply With Quote
