Old 08-26-2020, 12:28 PM   #1
Detonator
Detonator's Avatar
Default '35 Column Drop/Lock/Switch: Lube?
I'm reassembling my column drop after a clean up/repaint. When I disassembled it, it was pretty oily inside. It had obviously been worked on before, and if it's anything like the rest of the car, probably was done poorly. Does the sliding lock on these column drops get lubricated? If so, what would you suggest using? Thanks.
Seabright Hot Rods
Detonator is offline   Reply With Quote
Old 08-27-2020, 06:57 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: '35 Column Drop/Lock/Switch: Lube?
Dry lube such as LPS#1 or a little Graphite.
