Old 07-08-2020, 06:04 PM   #1
bobscogin
Default '29 roadster pickup sill plates
I'm installing reproduction sill plates on my '29 rpu and the bottom edge is rolled too far inboard to align with the bottom of the quarter panel. I'm not clear on how the bottom edge of the sill plate relates to the bracket on the sub rail , but I suspect I may not have it placed correctly in/on the bracket. Any suggestions?
Bob
bobscogin is offline   Reply With Quote
Old 07-08-2020, 06:30 PM   #2
Russ/40
Russ/40's Avatar
Default Re: '29 roadster pickup sill plates
I found them to be so far from correct, i used my rusted originals after some repair. The repos are on the shelf.
Old 07-08-2020, 06:56 PM   #3
bobscogin
Thanks, Russ. I sort of expected to hear that. My orignals were beyond repair. Fortunately, I'm pretty handy with metal, so I think I'll just reshape as needed. I'm still uncertain as to how the lower edge sits in/on the bracket. Anyone got a photo?
Bob
Old 07-09-2020, 01:36 AM   #4
Jembow
Jembow's Avatar
Just doing the same on my 28, I'd be interested in photos
Jembow is offline   Reply With Quote
Old 07-10-2020, 01:56 AM   #5
Randy in ca
Randy in ca's Avatar
I have no experience with those on Roadster Pickups, but assume that they are mounted the same as those on Roadsters and Phaetons, with the exception of around the different seat base. The ones I've used for Roadsters actually fit fairly well. Basically the lower outside bead should line up with the bead on both the cowl post and the panel behind the door and then the sill edge is wrapped under the subframe. Here's some pictures I posted several years ago of how things go on a Roadster.
File Type: jpg 1928-29 Ford Open Car DOOR SILL BRACKETS 003 (copy).jpg (59.6 KB, 99 views)
Randy in ca is offline   Reply With Quote
Old 07-10-2020, 02:01 AM   #6
Randy in ca
Another. For some reason it wouldn't post above any way but rotated. Still won't - no idea why, but thumbnail is right side up!!
File Type: jpg 1928-29 Ford Open Car DOOR SILL BRACKETS 006.jpg (60.7 KB, 46 views)
Old 07-10-2020, 10:47 AM   #7
d.j. moordigian
d.j. moordigian's Avatar
Correct and very well done with the photos Randy..
d.j. moordigian is offline   Reply With Quote
Old 07-10-2020, 11:04 PM   #8
bobscogin
Thanks, Randy. After a bit of massaging, I got mine to fit reasonably well. The passenger side is good, the driver's side less so. However, I attribute that to the fact that I had to do extensive rust repairs on the subrails on that side including bracket replacement and my repairs could be a little off.
Bob
