Old 07-12-2017, 08:14 AM   #1
René W
René W's Avatar
Default Where do you store the cranckhandle?
In my tudor is no space to store the crankhandle and jack so i put it behind the seat on the floor.
If my trunk is on the rack i can put it there but the trunk is not always on,only when i go on long runs without a trailer.
Where do you put the crankhandle and jack,tools etc.?
It is a pile of shit bit it's my pile of shit
René W is offline   Reply With Quote
Old 07-12-2017, 08:35 AM   #2
JOHN CT
JOHN CT's Avatar
Default Re: Where do you store the cranckhandle?
What's wrong with under the rear seat
It's not like you use it every day.
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 07-12-2017, 08:35 AM   #3
1930artdeco
1930artdeco's Avatar
I though that the Tudor tools were kept under the rear seat? I store mine either in the trunk or under the front seat in my car.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 07-12-2017, 08:57 AM   #4
abachman3
abachman3's Avatar
My crank handle is kept under the drivers seat in my tudor. The jack etc. is under the rear seat.
abachman3 is offline   Reply With Quote
Old 07-12-2017, 09:09 AM   #5
CB919ER
CB919ER's Avatar
I have a jack under the front seat and I found the crank in the floor next to the rumble seat. I'll probably keep both under the front seat.
CB919ER is offline   Reply With Quote
Old 07-12-2017, 09:13 AM   #6
JDupuis
JDupuis's Avatar
I keep the hand crank in a handy location. Under driver seat, or on floor in rear seating area. I am prone to drive a couple hundred miles at a time. Thus, I feel the need for a quick re-torque of all the wheels just in-case. I have the original tool pouch for each of my 5 model A's. I try to store the tool pouches under the rear seat, but I also keep a "travelling" tool box. That I take from car to car just in case. This travel tool box keeps my tuning tools, rags, bulbs, gloves, reading glasses, spare whatevers ect......
The trunk on the back of the tudor and the roadster are a godsend when travelling with friends in the cars. The biggest challenge I usually find is where to store the jug of coolant, so it doesn't tip over.
Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 07-12-2017, 09:43 AM   #7
Franchise_24
Franchise_24's Avatar
My crank handle is under my front seat.
1929 Model A Ford Coupe
Franchise_24 is offline   Reply With Quote
Old 07-12-2017, 10:34 AM   #8
Fullraceflathead
Fullraceflathead's Avatar
Mines under my seat in my Roadster Pickup
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 07-12-2017, 10:37 AM   #9
lindy williams
On most models there is room under the front seat. On a tudor there is room under the rear seat.
lindy williams is offline   Reply With Quote
Old 07-12-2017, 11:21 AM   #10
iverson
iverson's Avatar
My uncle told me when he was a kid he saw a lot of fights were cranks were used so they must have had them handy! Tough for the T driver
iverson is offline   Reply With Quote
Old 07-12-2017, 11:32 AM   #11
Big hammer
Under the rear seat in a tudor ! Just push the lower cushion back, then lift up. If you shocks aren't working, put some padding in there ! :-) Points, plugs, rotor, cap etc, no room for a starter or generator. Someone makes boxes that under the pan under the rear seat, but you have to cut two big holes each side of the drive shaft :-(
get a bigger hammer tap done
Old 07-12-2017, 12:17 PM   #12
RawhideKid
In my Tudor the crank is under the drivers seat and the jack is in my back pocket.
Before Walmart you had to buy a ticket to the fair to see a bearded lady!
RawhideKid is offline   Reply With Quote
Old 07-12-2017, 12:26 PM   #13
denniskliesen
denniskliesen's Avatar
The Tudor basement goes in front of the rear seat where the wood floorboard is.
http://www.snydersantiqueauto.com/storage-box
denniskliesen is offline   Reply With Quote
Old 07-12-2017, 12:30 PM   #14
Big hammer
Thanks for correcting me !
Old 07-12-2017, 12:30 PM   #15
CHuDWah
CHuDWah's Avatar
Doesn't that make sitting kinda uncomfortable?
I stored tools under the seat - small stuff in the pouch and crank and jack wrapped in shop rags to keep from rattling (also good for wiping hands). Course that was a coupe that had a handy under-seat pan for the purpose. How about a toolbox on the running-board? More common on Model T but should work on A - don't think they're reproduced but original examples aren't too uncommon.
CHuDWah is offline   Reply With Quote
Old 07-12-2017, 12:36 PM   #16
DougVieyra
DougVieyra's Avatar
Leave the crank behind.
Park on a hill . . . .
DougVieyra is offline   Reply With Quote
Old 07-12-2017, 12:41 PM   #17
denniskliesen
All of my tools, jack and handles, crank handle, towels, go under the rear seat.
Old 07-12-2017, 02:19 PM   #18
RawhideKid
Not when it's the AAA card and the fellow using his jack and handle are changing the tire!
Old 07-12-2017, 03:14 PM   #19
Stew Masche
Stew Masche's Avatar
Crank usually sits in the passenger seat.
Always one bad decision away from a good time.
Stew Masche is offline   Reply With Quote
Old 07-12-2017, 03:21 PM   #20
Big hammer
My dad wanted my hand crank! because he didn't want me hand cranking.
But dad want if I have a flat and need to put on the spare? Don't hand crank it, if it doesn't break your arm, I will ! Yes I did, many years later, it started right up!
