03-23-2019, 04:34 PM | #1 |
1930 Model A top
I am trying to figure out how much chop a 1930 Ford coupe has. Can someone give me a measurement of a corner of a windshield or door window opening in the center on a stock 30 standard coupe?
03-23-2019, 07:05 PM | #2 |
Re: 1930 Model A top
"I'm trying to figure out how much chop a 1930 Ford coupe has."
What do you mean by "how much chop"? "Can someone give me a measurement of a corner of a windshield or door window opening in the center" Measurement from where to where? Which corner? In the center of what?
All steel from pedal to wheel |
03-23-2019, 07:16 PM | #3 | |
03-23-2019, 07:21 PM | #4 |
OK...I get it.
You have a Model A coupe with a chopped top and you want to know how much it has been chopped. You want a measurement from a stock car of either the vertical post of the windshield, OR of a door window from the center of the top of the window to the bottom of the glass. I can get those measurements for you tomorrow if no one responds before then.
03-23-2019, 07:30 PM | #5 |
Yes...Either way. Measuring the vertical portion of the w/s frame on the outside next to the pillar also works. Car is supposed to be chopped 2 1/2" but I think closer to 3 1/2.
03-24-2019, 11:19 AM | #6 |
All steel from pedal to wheel Last edited by Dick Steinkamp; 03-24-2019 at 12:14 PM. |
03-24-2019, 04:40 PM | #7 |
Windshield is the same,but the doors are not.The window opening on a coupe is about 13-1/2,and the tudor is about 14-1/2. That is the measurement taken in the center of the window opening,as in Dick's picture.In 30-31 the coupe doors are all by themselves,and the 30-31 tudor and closed cab pickup are the same.
03-24-2019, 06:33 PM | #8 |
Thanks...My coupe window opening in the center is right at 10" .I am figuring about a 3" chop.
