09-04-2015, 02:41 AM | #1 |
Gearbox thrust washers
I,m building up a spare gearbox ,and in my stuff there is a new cluster gear thrust washer,it is babbit coated,is this Ok to use,
Lawrie |
09-04-2015, 09:26 AM | #2 |
Re: Gearbox thrust washers
It should be, all of my thrust washers for the 4 notch cluster are babbited. Paul J.
09-04-2015, 09:35 AM | #3 |
Yes
09-04-2015, 12:28 PM | #4 |
LAWRIE. how about a picture of your Aussie thrust washer. Just wondering if it is the same as my unobtainable Canadian thrust washer? Thanks Rich
09-04-2015, 03:23 PM | #5 |
Will do this morning.
Lawrie Last edited by Lawrie; 09-04-2015 at 04:30 PM. |
09-04-2015, 06:10 PM | #6 |
09-04-2015, 09:03 PM | #7 |
Brian.
What stops the steel spacer between the thrust washer and the rear of the case from turning? you got any of the thrust washers? Lawrie |
09-04-2015, 09:22 PM | #8 |
That's what I want to know Lawrie.. As some have this setup with an intermediate washer between are they the better ones to use if the thrust face on the case is not so good?
Not sure I've seen the type you have pictured?
09-04-2015, 09:45 PM | #9 |
Those look the same as my 52 truck 3-sp uses, Van Pelt sells them. Mine spun, scored the case surface. I put some Loctite product on the case surface before assembly, with new washers, looked fine 8k miles later when I disassembled for something else.
'52 F-1, EAB flathead |
09-04-2015, 10:09 PM | #10 |
Well I didn,t trust the thin spacer not turning ,so I made up a little tool and put a 3/8 dimple in it to locate in the groove that lets oil done to the rear cluster bearing,that stopped it turning.
Lawrie |
09-04-2015, 11:23 PM | #11 |
Lawrie, I had the same problem with my Canadian trans. We made one out of the U.S. Washer that has the smaller round hole the size of the shaft. Thickness and finish was the same. We did a simple program on the CNC mill and it came out perfect. If you are stuck and cannot get it done in your neck of the woods, we'll let me know. I think I posted some pics back a while on this.
09-04-2015, 11:25 PM | #12 |
Sorry I guess that last was meant for Deuce Man.
09-05-2015, 12:17 AM | #13 |
Lawrie, Exactly which thrust washers are you enquiring about?
09-05-2015, 02:05 AM | #14 |
Brian ,like the ones in my picture.
Lawrie |
09-05-2015, 03:21 PM | #15 |
Lawrie, Sorry, I do not. Never seen such a critter; only the illustration of same in my Canadian Fast Moving Parts Catalogue, from which I got the part no and description as in my earlier post. I'll put through a call to Ajays tomorrow on your behalf; see if they've got one. Let you know, Brian
09-05-2015, 03:32 PM | #16 |
I've thought about doing that when I build a trans using the later type rear thrust washer. Sounds like it worked OK for you. Thanks for posting the info. Paul J.
09-05-2015, 03:39 PM | #17 |
Yes Brian you could ask Brian at jays for me.
thanks Lawrie |
