05-14-2014, 11:18 PM | #1 |
Brake Drum Machining
Did any tool maker build a brake drum lathe for the rear integral hub/drum of early (40) Fords. All the lathe arbors seem to be too big for the 3/4 inch hole in the hub. Could not find one in KRW books.
05-14-2014, 11:52 PM | #2 |
Re: Brake Drum Machining
I got one for my Van Norman 204, so do a lot of the older shops... Amco also has one available... Might be a bit of a hunt, not too bad tho...
Karl |
05-15-2014, 04:04 AM | #3 |
my buddies ammco had an arbor that fits
05-15-2014, 05:37 AM | #4 |
Avro,
I have an AMMCO brake drum lathe with the correct arbor. Charlie ny |
05-15-2014, 09:06 AM | #5 |
The barrett (sometimes branded different) has an adapter that fits in with the wheel bearing and seal in place centering the hub the same as it is on the car, by the wheel bearing not the axle, the machine also doesn't cut a spiral like most machines, it makes a little more than a revolution then moves a little ---even a coarse cut can't cause the shoes to be pushed sideways by rotation
05-15-2014, 11:19 AM | #6 |
Bob |
05-15-2014, 07:03 PM | #7 |
the small arbors are on e bay constantly.for the ammcos any way.
