Old 07-14-2022, 08:05 PM   #1
S.Duncan
Default Need a dimension;34 ford
I'm installing my recored stock 34 rad and the stay rods are new. I don't plan on running a hood for a while so I need a measurement from lip of the top of the firewall in the center to the back of the rad stay rod bracket. Any help is appreciated
S.Duncan is offline   Reply With Quote
Old 07-14-2022, 08:20 PM   #2
Digger
Digger's Avatar
Default Re: Need a dimension;34 ford
Hello S, I can do any measurements you want on my 34, but the measurement you describing would vary based on if the radiator was push forward or backward because when it’s not attached it has a lot of wiggle room, but I can give you the measurement of how mine is with the stock rods in place and tighten down
Digger is offline   Reply With Quote
Old 07-14-2022, 08:46 PM   #3
S.Duncan
Thanks Digger I'm looking for a measurement on a stock 34 with a hood and a stock rad and firewall.
Old 07-14-2022, 09:14 PM   #4
Digger
Digger's Avatar
From the front lip of the firewall to where the rods attach on the radiator rod bracket is 28.75”. See photo
File Type: jpg 01D392F5-7DF2-45C1-ADBA-668DC9C878FD.jpg (59.6 KB, 52 views)
File Type: jpg 7C8758E9-2DA9-4E78-8FFC-0AE08045AA0E.jpg (76.8 KB, 20 views)
Old 07-14-2022, 09:20 PM   #5
S.Duncan
Thats great,thank you
