04-30-2019, 06:58 PM | #1 |
49-51 Ford Convertible Model O.D. Solenoid
Does the 49-51 Ford CONVERTIBLE model , with the X frame chassis require a special Overdrive Solenoid ( with a flattened corner shape) to clear that X frame? I remember the mid 50's Ford CONVERTIBLES required that special shaped O.D. solenoid in order to clear the frame , not sure if the 49-51 models did as well.
Steve |
04-30-2019, 09:52 PM | #2 |
Re: 49-51 Ford Convertible Model O.D. Solenoid
Don’t hold me to this as my ‘50 convertible doesn’t have an overdrive, but I seem to recall the convertible OD was a different OD from the non-convertible (X member absent) cars. The convertible OD positioned the solenoid at a downward angle to clear the frame vs the standard OD where the solenoid mounted essentially horizontal. Again, don’t hold me to it as I’m really digging in the archives here; I’m not getting any younger.
05-01-2019, 01:07 AM | #3 |
Hi; I understand that they are mounted differently ... require a special casting. Newc
05-01-2019, 05:44 AM | #4 |
This link to our parts drawings shows the particular mounting of the 49-50 Ford convertible arrangement for the overdrive solenoid. I believe this was not used after 1950 converts due to a change in the frame.
05-01-2019, 06:08 AM | #5 |
The solenoid is also specific to a convertible. The shaft needs to be rotated one flat if I remember correctly or it might just be different. Either way a regular one will not just bolt up. There is a weep hole on the cover and that needs to be positioned at the bottom.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
05-01-2019, 06:37 AM | #6 |
Steve |
05-01-2019, 06:58 PM | #7 |
No you need to disassemble it but not a big deal. Here is the Ford drawing
05-02-2019, 07:16 AM | #8 |
Frank....thanks for your info on this. Could I ask you to send that diagram to my regular email?
This Ford Barn system does not allow me to magnify the attachments so they are readable, I think I can do that if its an email attachment. Hope that isn't too much trouble for you to do. [email protected] Thanks again ! Steve |
