01-28-2023, 04:38 AM | #21 | |
Re: A new thread!! Firestone Bias Ply Tires
It won't sound FUNNY once you actually experience driving on BIAS tires, then changing to RADIAL tires on the same vehicle. Night & day difference. Coop . |
01-28-2023, 08:30 AM | #22 |
I have used Firestone bias on many cars over the years. I have them on my two 32 Fords I own now. They have been very good. I do not use the tubes from Coker however. I get the tubes from my local tire shop. They are heavier.
A man should do what he thinks best! "The Duke" |
01-28-2023, 11:10 AM | #23 | |
FYI - I park on “Flatstoppers” and have found that they help for a smooth ride. Also, double check that the tires spin true when new. Every now and then one is slightly out of round and either needs to be replaced or shaved. |
01-28-2023, 11:32 AM | #24 |
I've had several sets of Firestone bias ply tires, always with tubes. Has anybody out there put them on '40 Ford wheels without tube? I've heard it's been done.
01-28-2023, 04:00 PM | #25 |
I'm inclined to agree with OldGold360 about bias ply tires. I put a set of Coker classic-look radials on my '36 pickup, which has an entirely stock suspension; after a seemingly never-ending series of pinch flats, despite heavy duty radial specific tubes and 40 psi inflation, I went back to Firestone bias tires. I have never had another pinch flat. My driving is a mix of freeway, in town, and country back roads; it tracks perfectly true on the freeway at 55-60 without any problems, and I really didn't see much advantage to the radials driving at reasonable speeds on curvy roads. I would never consider bias ply tires on any other car I own, but for the '36 they work really well. I actually wound up giving the set of radials to a local 'Barner when I switched back to bias ply.
Adam
1936 pickup, stock, black 1965 Mustang coupe 289/4bbl, black/red 1971 Alfa Romeo GTV 1750 coupe, dark red/tan 1970 911E 2.2 litre dark blue/black 1968 BMW R50/2 US, black (m'cycle) 1967 Triumph TR6R , sea foam/cream (m'cycle) 2022 Royal Enfield Interceptor 650 red (m'cycle) 1974 Honda CB750 red (m'cycle) 2000 Kawasaki W650 blue/silver (m'cycle) |
01-28-2023, 05:38 PM | #26 | |
