Old 09-19-2018, 08:28 PM   #1
daren007
Default Model A tappets
Snyder’s gives the tapper diameter as .5930/.5935. My tappets measure .5910. My question is what diameter should standard tappets be.
Daren
daren007 is offline   Reply With Quote
Old 09-20-2018, 11:58 AM   #2
Jim Brierley
Default Re: Model A tappets
As Snyder's says. I think they also make them in oversize in case your block is worn. Bottom line is there should be no side-to-side movement felt or they will be very noisy! I have used Chrysler tappets, .625". Only minor reaming of the block is needed to fit these in.
Jim Brierley is offline   Reply With Quote
Old 09-20-2018, 01:00 PM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Daren
Daren, do you mind me asking exactly how you measured yours? Is it possible your measuring device is what is throwing you off? If you recall, several engine rebuilders told you that 0.001 - 0.0015 is the desired clearance, and I posted a picture showing you the proper lifter bore size. If you do the math, 0.5945 - 0.5930 pretty much puts you with the proper specification.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
