03-18-2018, 10:16 AM | #1 |
back firing through tailpipe
My 8rt is back firing through the tailpipes at low rpm. as rpm increases to 800 it stops. What causes this? The timing is set right and I double checked the firing order. Thanks Mike
03-18-2018, 10:20 AM | #2 |
Re: back firing through tailpipe
Exhaust valves that are hanging up?
03-18-2018, 11:11 AM | #3 |
Use Marvel Mystery Oil in the gas.
03-18-2018, 11:44 AM | #4 |
could be lean
03-18-2018, 11:48 AM | #5 |
03-18-2018, 12:01 PM | #6 |
I've done this on my truck that has a new rebuilt motor with low miles. Usually in the spring after its been sitting for a few months, I MMO it and it frees up the valves everytime. My condition is a bit different though. Idle is fine, underload or at higher rpms it will buck and pop. Worth a try as its fairly simple procedure, wont hurt anything, and cheap to do. . Last edited by Tinker; 03-18-2018 at 01:22 PM. Reason: Sentence structure. |
03-18-2018, 05:17 PM | #7 |
Tinker-Plugs are clean, light gray and slightly brown. I'll try some MMO and see what happens. How much per gallon of MMO?
03-18-2018, 05:53 PM | #8 |
I think there are directions on the bottle. Few ounces pre tank, should be good. I usually just pour in a bit less then a 1/4 of the qt bottle on a fill up. But I don't use it on every fill up.
Others here probably have a proper mix formula that they use. I'm also one of those cooks that goes "a dash of this, and a splash of that!". I would drizzle some down the carburetor till you get some smoke and smell that MMO burning. Then drive it with some in the tank. But the drizzle will kick start the oiling. Last edited by Tinker; 03-18-2018 at 06:30 PM. |
03-18-2018, 06:00 PM | #9 |
Sticky valves as mentioned, burned valves, or a leaky carburetor can all cause after fire in the exhaust. Sticky or burned valves will generally show up on a compression or leak down test. A leaky carb body will drain the float bowl and be hard to start sometimes. It can run rough at idle plus possible after fire if too rich.
03-18-2018, 06:31 PM | #10 |
Vacuum gauge should show a sticky valve also.
03-19-2018, 11:16 AM | #11 |
have a steady reading of 19 0n vacuum gage. I don't have another carb to check against. but sounds like a leaking carb. I have to crank it awhile on first startup of the day. who does carbs on the barn? Mike
03-19-2018, 11:35 AM | #12 |
Four (4) fluid ounces per 10 gallons of fuel. It's not a critical measurement though, "a few glugs" per tank is probably close enough. I usually measure it to stretch the supply out though. It does work; infrequently driven engines are subject to fuel souring or varnishing in the carburetor, stuck rings and lifters, valves etc.
03-19-2018, 12:41 PM | #13 | |
716 662 9159 716 440 8952 Charlie Schwendler Charlie ny
Enjoy yer day. Tom Hate can't fix what it started. |
03-19-2018, 01:07 PM | #14 |
I had some back firing like yours it wasn't, all the time.
I think its the 2 middle exhaust together firing left over gas or miss fire. |
03-19-2018, 01:25 PM | #15 |
Tinker
Once you get them Unstuck, use a couple of caps of MMO in every fill up of gas from here on out!!! |
03-23-2018, 08:52 PM | #16 |
So you get a chance to mess with it?
03-23-2018, 10:27 PM | #17 |
Vacuum on a idle car might be inconclusive. Since your issue is not at idle as much as under-load. I have added a full time vacuum gauge to the dash just because.
03-24-2018, 11:11 AM | #18 |
If points are to close that can cause backfire at tailpipe Check points setting.
03-24-2018, 12:07 PM | #19 |
To eliminate the valves, do a compression, or leak down test.
12-27-2018, 09:16 AM | #20 |
My 59ab backfires through the tailpipe, but only on deceleration. There are some fairly long grades here, so I need to address it. Engine is fairly worn, carb rebuilt, but I may not have switched the power valve, which I don't really understand. Recent Bubba crab. Other than the backfire, a good runner and easy starter.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
