Old 11-13-2014, 08:33 AM   #1
Terry, NJ
Terry, NJ's Avatar
Default Rear seat in a Town Sedan, Wood base
I'm building the rear seat for my Briggs 30 T.S. and the wood is so far gone I can't get and dimensions from some of it or it is missing altogether. The dimensions I need are for the rear piece that goes across the rear of the seat base. I can get the Length, but I need the width of the piece and the radii of the corners. Thanks in advance.
Terry
Terry, NJ is offline   Reply With Quote
Old 11-13-2014, 12:09 PM   #2
Terry, NJ
Terry, NJ's Avatar
Default Re: Rear seat in a Town Sedan, Wood base
B to T
Old 11-13-2014, 02:18 PM   #3
MichaelSchwarzer
MichaelSchwarzer's Avatar
Hi Terry,
I am in the process of restoring an early 1930 TS from France. Unfortunately it had no back seat. But I was able to buy one at ebay. The seller said, it was from an early 1930 TS, but of course i can't be sure. But it fits in the car. The dimensions of this seat you require are:
width of the rear piece: 3" 1/16
Radius of corner: 3/4"
I hope I understood your question correctly, if not please tell me. The attached pictures should show the measuerements in inches.
Michael
www.fordmodela.com
MichaelSchwarzer is offline   Reply With Quote
Old 11-13-2014, 04:21 PM   #4
Terry, NJ
Terry, NJ's Avatar
Michael, Thank you for this. I will send you pictures of what I've made so far and the two original pieces I used for a pattern. I can work in wood and metal but not computers, I'm too old and my skills don't extend as far as adding pictures in a posting. What you posted pictures of, seemed correct. Except for the damage in the front corner.
Terry
Old 11-13-2014, 05:05 PM   #5
Terry, NJ
Terry, NJ's Avatar
Michael, Go to my profile and go to "MY A" , The pictures are the first ones.
Terry
Old 11-14-2014, 01:51 PM   #6
MichaelSchwarzer
Terry,
thanks for the pictures. so I can be pretty sure to have the correct seat. Your reconstruction process looks much more elaborate than mine. With my A I am just before the final assembly,, can I asked you some questions if I cant get any further?
Michael
www.fordmodela.com
