Old 04-01-2014, 02:24 PM   #1
Ford_Freddie
Default 1930 Ford A Deluxe with original upholstery
Hello, I'm a Model A beginner. At the moment I look for a car. In Germany it is not so easy to find a good Model A. I like cars with patina - maybe this one has a little bit to much of it. The blurry headlining seems to be the result of rotten woodwork. What do you think of the car? Is it worth an 8 hour trip? The Ford is comparatively cheap. Thank's a lot for your help.
Ford_Freddie is offline   Reply With Quote
Old 04-01-2014, 02:35 PM   #2
juke joint johnny
juke joint johnny's Avatar
Default Re: 1930 Ford A Deluxe with original upholstery
Wellcome to the Barn Freddie !!
That looks like a very nice Sedan .You don't find many with original upholstery .
There is a lot of wood in the 4 door sedan so Check out the wood on the subframe and if the doors shut nice that's a good find.
John Cochran
juke joint johnny is offline   Reply With Quote
Old 04-01-2014, 02:41 PM   #3
Ford_Freddie
Thank you John!
Old 04-01-2014, 03:19 PM   #4
Joop
Joop's Avatar
Herzlich willkommen Freddie.
Where is Rosenheim in Germany.
Where is the car located located?
Maybe you can get a local Model A'er check it out first.
It has a different spare tire bracket also.
Joop is offline   Reply With Quote
Old 04-01-2014, 04:01 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
I would like to own that car.
If it has a new top, then the stains may be from the old one and nothing to worry about.
Old 04-01-2014, 08:18 PM   #6
bikejunk
Considering its age and how fragile (even when new) the interior is, its reall a well care for car , keep it preserved for the next generation to study. good luck
bikejunk is offline   Reply With Quote
Old 04-01-2014, 10:00 PM   #7
Mike V. Florida
Mike V. Florida's Avatar
Nice 30 Town sedan!!!
Old 04-01-2014, 11:05 PM   #8
Jim Huseby
Jim Huseby's Avatar
It certainly looks attractive in the photos. Some things you could do to help you assess the car's structural wood condition is to open the doors a little and lift them up and down to determine if the hinges are loose in the wood. You should also shake the body by pushing sideways on the door posts to see if the body is rigid or not. Look at the windshield frame from the front of the car to make sure the frame fits square and level in the opening. Get permission to open the windshield to make sure its hinge fits tight to the header; while it is open, see if it sags to one side or drags at the bottom. Sometimes the wood can be structurally usable with loose screws where I described and the wood can be repaired in the screw hole areas easily, but don't get your hopes too high. Look along the top to see if the structure under the exterior top material looks uneven or sags. Wood replacement is a major undertaking, and you may or may not enjoy the challenge, if necessary. Can you get a Model A-er to look at the car with you? Keep posting questions. Good luck.
Jim Huseby is offline   Reply With Quote
Old 04-01-2014, 11:52 PM   #9
Tudortomnz
Tudortomnz's Avatar
If I was after a nice Fordor, I would certainly travel to see that car.
Look at the wood at floor subframe & check for any up/down movement at all the door hinges where they screw to the pillars.
Tudortomnz is offline   Reply With Quote
Old 04-02-2014, 02:04 AM   #10
Ford_Freddie
I thank you so much for all your helpful advice.
Rosenheim is in the south of Germany (Bavaria) and the car is located in the east (Dresden). The Model A'er I know is not very familiar with a Fordor.
Old 04-02-2014, 05:03 AM   #11
MichaelSchwarzer
MichaelSchwarzer's Avatar
Hi Freddie,
We restore a Briggs Townsedan like the one you show. The wooden structure is visible just now. See webpage in signature. I live in Gmund am Tegernsee, 30 km from Rosenheim. If interested you may visit our workshop.
May be I could give some advise. Please send a private message if interested.
Michael (I am German)
www.fordmodela.com
MichaelSchwarzer is offline   Reply With Quote
Old 04-02-2014, 05:15 AM   #12
eystein
eystein's Avatar
Of course the car may have hidden faults, however, the tips in the posts above gives good advice how to find out.
If the car is what it looks like, you will probably never find another original car as good as this. Unless it is overpriced it is definately worth the trip in my opinion.
eystein is offline   Reply With Quote
Old 04-02-2014, 08:51 AM   #13
1930artdeco
1930artdeco's Avatar
Welcome Freddie,
Just from the pics I saw, the original shades are still in her! That means that hopefully the rest of the interior is still original. That is a VERY good thing. Along with the above tips, when-not if but when-you go see her check out the drive train. Make sure there is no knocking in the engine and that she shifts smoothly.
It looks like she has been repainted at some point in her past and the engine may have been opened up. Also, as a side note you are looking at a BRIGGS bodied car and there parts do not interchange with a MURRY bodied car (body wise).
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
