10-05-2021, 04:55 PM | #1 |
Help I知 Lost
So, I just put on a freshly rebuilt Holley onto my 34 Ford (not correct carb for 34痴 but was on the car when I inherited it) I am getting fuel to the carb and I can see it shoot out the jets. Now that痴 all great but the engine is still not firing even after I have put on a rebuilt distributor, new spark plug wires, new spark plugs, and getting gas into engine. I am at a complete loss. Any help would be greatly appreciated!!
10-05-2021, 05:04 PM | #2 |
Re: Help I知 Lost
Time to get out your multi meter/volt meter. Check for voltage to the ignition switch and
at the coil with the ignition switch turned on....
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 10-05-2021 at 05:10 PM. |
10-05-2021, 05:14 PM | #3 |
Re: Help I知 Lost
10-05-2021, 05:44 PM | #4 |
Re: Help I知 Lost
What was wrong that caused you to change these parts? Was it a running car beforehand?
10-05-2021, 06:02 PM | #5 |
Re: Help I知 Lost
10-05-2021, 06:12 PM | #6 |
Re: Help I知 Lost
Like this: |
10-05-2021, 06:56 PM | #7 |
Re: Help I知 Lost
10-05-2021, 10:05 PM | #8 |
Re: Help I知 Lost
Remember that the #1 cyl. on a Ford Flathead is on
the right front (pass side) of engine, if it is LHDrive. It's odd to have the #1 cyl., not be the furthest forward, as the #5 cyl. on a Ford flathead is further forward. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
10-06-2021, 08:06 AM | #9 |
Re: Help I知 Lost
Thank you for this reminder. Something else I was thinking about, is it possible something crawled into the exhaust pipe and has stopped it up? Thank you.
10-06-2021, 08:16 AM | #10 |
Re: Help I知 Lost
Yes it’s very possible.....it’s almost a guarantee .......but the motor would still fire if you have fuel,spark and air......did the rebuilt distributor come with a new condenser?......Mark
10-06-2021, 09:05 AM | #11 |
Re: Help I知 Lost
Just got done checking voltages. Starting at the battery there are 6.4 volts and at the coil I am getting 2.4 volts. Mark, condensers for these distributors are crazy hard to find now. I found a condenser with an original strap soldered on.
10-06-2021, 10:01 AM | #12 |
Re: Help I知 Lost
Since it's obvious that you have a later 8BA-type engine and not a '34 ignition system, the schematic someone posted is not representative of what you have. Mac VanPelt kindly posts most of these drawings for our use. This drawing BELOW should be more appropriate for troubleshooting your later distributor/points/condenser. DD |
10-06-2021, 10:11 AM | #13 | |
Re: Help I知 Lost
10-06-2021, 10:12 AM | #14 |
Re: Help I知 Lost
What is the required voltage needed at the coil like I said I was getting 2.4 at the coil.
10-06-2021, 10:18 AM | #15 |
Re: Help I知 Lost
Duh! I obviously misread Mart's post up above and assumed (ASS-U-ME) that the engine head shown in his picture was yours....SORRY! DD . |
10-06-2021, 01:30 PM | #16 |
Re: Help I知 Lost
34 fordor owner, maybe list your location in hopes that
a member might be close enough to come help you .
10-06-2021, 02:15 PM | #17 |
Re: Help I知 Lost
10-06-2021, 02:30 PM | #18 |
Re: Help I知 Lost
Maybe someone close will see this thread, and come and help.
My '40 at one time, years ago, after sitting a long time, would just spitter and sputter while trying to start it. An old car guy came over, pulled the front distributor, and filed and set the points, stuck it back together, and it fired up. .
10-06-2021, 03:00 PM | #19 | |
Re: Help I知 Lost
10-06-2021, 08:09 PM | #20 |
Re: Help I知 Lost
Does anyone have a good recommendation of where to get a good coil for a dome distributor?
