07-22-2021, 10:59 AM | #1 |
1938 fan shroud
Has anybody had any luck making a fan shroud for a delux 38 ?
07-22-2021, 01:55 PM | #2 |
Re: 1938 fan shroud
Vintage Air makes an ABS plastic one but the fit description reads 1937, 38, 39 standard. Now a 39 standard would be like a 38 Deluxe so I figured it might be worth a mention.
I have made a lot of fairings for the helicopters from fiberglass over the years. I use foam as a make up buck since it can be removed after forming. Fiberglass isn't my favorite material to work with but it can be made to work with minimal cost. |
07-22-2021, 01:55 PM | #3 |
Re: 1938 fan shroud
repeat error
07-22-2021, 02:04 PM | #4 |
Re: 1938 fan shroud
I have yet to make one for my '38 deluxe but here are some pictures FlatheadTed shared with me of one he made for his('36 if I remember correctly).
Sometimes, ingenuity gets in the way of sense and sanity. |
07-22-2021, 02:55 PM | #5 |
Re: 1938 fan shroud
some more
07-22-2021, 06:00 PM | #6 |
Re: 1938 fan shroud
07-23-2021, 08:22 AM | #7 |
Re: 1938 fan shroud
Instead of adding a shroud, why not fix the overheating problem??
Paul in CT |
07-23-2021, 10:09 AM | #8 | |
Re: 1938 fan shroud
07-23-2021, 10:15 AM | #9 |
Re: 1938 fan shroud
[QUOTE=Will D;2038528]I have yet to make one for my '38 deluxe but here are some pictures FlatheadTed shared with me of one he made for his('36 if I remember correctly).
Will .....My question is: Is that a '36 PICK-UP, rather than a '36 CAR? If so, like-year pick-ups have way more room because the radiator doesn't lean-back in a pick-up near as much as the CAR radiator. Dick D |
