01-06-2021, 06:49 PM | #1 |
Roadster Door Hinge Screws
I need several of the screws that hold the door hinge to the car body. The screws I’ve bought from vendors don’t fit. Does anyone know what size these screws are ? There are three screws on each hinge.
Thanks - Jim |
01-06-2021, 09:54 PM | #2 |
Re: Roadster Door Hinge Screws
Need to know what year roadster,
1928-1929 roadsters use 1-4-28 for door hinge to cowl 1930-1931 roadsters use 5/16-24 for door hinge to cowl Steve |
01-07-2021, 09:47 AM | #3 |
Steve - thanks - the car is a ‘31 roadster.
Jim |
01-07-2021, 10:06 AM | #4 |
got mine from Brattons and they fit fine.
01-07-2021, 03:22 PM | #5 |
If you got the screws from a reputable supplier and for the correct year, make sure the holes were not re-tapped for different thread or cross threaded. If you have the old ones that came out, check the thread count.
I know the voices aren't real but damn they have some good ideas! |
01-07-2021, 03:35 PM | #6 |
01-07-2021, 06:36 PM | #7 |
Just did the hinges on my 31 Roadster a short time ago. Used some original screws and some new ones from Bratton's and they worked fine. Make sure you use the cup washers and internal lock washers as well.
