Old 01-19-2021, 08:02 PM   #21
McMimmcs
McMimmcs's Avatar
Default Re: Toilet paper oil filter adapter
Originally Posted by tubman View Post
The Frantz and other filter assemblies specifically designed to use toilet paper did not have this problem. I occurred when some cheapskate tried to run it in a regular canister system designed to use a cartridge filter.
What you say is indeed correct?
Old 01-20-2021, 11:09 AM   #22
1948F-1Pickup
1948F-1Pickup's Avatar
They're still in business, as I thought.....
https://www.toiletpaperoilfilter.com...ercompany.html
1948F-1Pickup is offline   Reply With Quote
Old 02-01-2021, 03:06 AM   #23
dwollam
dwollam's Avatar
My '29 Tudor with a 59a engine has had a Frantz filter on it since 1958. Original owner builder runs one on his 260Z too. Modern toilet paper will NOT work! Biodegradable so they break down with water moisture. One has to buy there filter rolls now.
Dave
dwollam is offline   Reply With Quote
Old 02-01-2021, 09:12 AM   #24
fordwife
That being said , what is the advantage, if any over modern oil filters? None in my opinion.
fordwife is offline   Reply With Quote
Old 02-01-2021, 10:32 AM   #25
Blastfromthepast
I agree fordwife, or find a company that make toilet paper that’s strong enough for the filter. It might work.
I don’t know how its use would work In the bathroom? Pretty rough stuff. Lol.
Blastfromthepast is offline   Reply With Quote
Old 02-01-2021, 11:58 AM   #26
Automotive Stud
Automotive Stud's Avatar
Agreed, it's not like toilet paper rolls are any cheaper than regular oil filters.
Automotive Stud is offline   Reply With Quote
Old 02-01-2021, 12:40 PM   #27
tubman
tubman's Avatar
Since Frantz filters are bypass filters, they really are not much help on a flathead Ford that already has a bypass unit. If the engine originally had no filter, I think adding a Frantz would not be a bad idea.
On an engine with a full flow filter, adding a Frantz as a bypass unit allows smaller particles to be filtered out of the oil over time. Using a combination of full flow and bypass filters is a common practice in large over the road trucks and other commercial applications.
Old 02-03-2021, 06:12 PM   #28
BillCook
Send a message via Yahoo to BillCook
While on leave in Calif in 1970 my uncle handed me a roll of toilet paper and asked if I could change the filter on my cousins 63 galaxy,I kinda looked at it and asked what was I supposed to do with the toilet paper ,well he took me outside open the hood and there wAs a canister ,if I remember correctly he unscrewed the top and there it was TP ! ,was an easy change !
BillCook is offline   Reply With Quote
