Old 01-26-2023, 05:20 AM   #1
ford nut
ford nut's Avatar
Default 36' header panel, tack strip diagram. .
does anybody out there have a drawing or photos of how this goes together? i'm missing the tack strips, so it's not lining up so good. i can only go so far with the mock-up. i have an ad in the wanted section, maybe they will turn up.
ford nut is offline   Reply With Quote
Old 01-26-2023, 10:47 AM   #2
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: 36' header panel, tack strip diagram. .
Maybe Don Rogers could help you with this. I have some '36 header panels, but have no idea how the tack strip(s) are located behind the panel or what they may look like. Although I probably do have most of that information for closed '35 sedans and coupes.
John
Old 01-26-2023, 04:22 PM   #3
ford nut
ford nut's Avatar
i have the panel now and thought it would just bolt up. but holes don't line up. then i found a pic. with another part that i'm missing. the tack strips. so i'm looking for those. one guy said he has them, but we'll see. says he has to find them and will let me know. but i need them, so if you got em' let me know.
Old 01-27-2023, 12:23 PM   #4
JM 35 Sedan
I do not have any tack strips for 36 header panels, I just have a couple sheet metal panels.
John
Old 01-27-2023, 01:01 PM   #5
Don Rogers
Don Rogers's Avatar
Here's some pictures of the tack strip that goes behind the header panel.
Don Rogers is offline   Reply With Quote
Old 01-27-2023, 01:11 PM   #6
ford nut
ford nut's Avatar
great photos. thats what i was looking for, thanks. now i just need to find them.
Old 02-04-2023, 07:47 AM   #7
ford nut
ford nut's Avatar
any idea how thick the tack strips are? 1/4", 5/16",3/8"? i think i might have to just make them. i have three more questions for anybody that might know,
1st, are there threaded nuts attached to the back of the tack strips for the header panel to screw to with machine screws?
2nd, do the tack strips mount to the body with machine screws, or sheet metal screws?
3rd, with the tack strip in place, would the top of the header panel be flush with the top of the tack strip? not over hanging? as in the same contours?
sorry for all the question, but missing parts make it tough.
Old 02-04-2023, 10:29 PM   #8
Gary Tosel
Gary Tosel's Avatar
1. No, sheet metal screws, therefore no need for back side nuts.
2. The tack strip is attached to the body with sheet metal screws,.
3. Flush with header panel, since headlining tacks to strip, then header panel is installed over the strip with screws and eschusions.
Gary Tosel is offline   Reply With Quote
