01-25-2023, 10:09 AM | #1 |
Shuddering And Hammering When Using 1st And Reverse
My original and unrestored 28 Tudor hammers and shudders when engaging the clutch at a standstill in 1st or reverse. I suspected an oil soaked clutch disc (not a muliti disc) due to a rear main leak but after pulling the engine and transmission that is not the case.
What should I be looking for? A bad input shaft bearing perhaps? Thank you in advance... |
01-25-2023, 10:25 AM | #2 |
Re: Shuddering And Hammering When Using 1st And Reverse
It may be clutch chatter caused by misalignment, oil/grease contamination, a warped flywheel, damaged clutch disk or a warped / damaged pressure plate.
It has been my experience that clutch chatter causes transmission oil to splatter into the bell housing and contaminate the clutch. Over-filling the transmission can cause this.
Bob Bidonde Last edited by Bob Bidonde; 01-25-2023 at 10:35 AM. |
01-25-2023, 11:06 AM | #3 |
Sure sounds like clutch chatter. It's usually a warped/heat checked flywheel or mis adjusted pressure plate fingers. A bad disk or unsprung disk can contribute to it.
Oil contamination will cause it, but, I've not found that to happen. I find this stuff easier to remove the transmission rather than the engine. Plus I can lay under there and take a nap. |
01-25-2023, 01:27 PM | #4 |
Does the surface on the flywheel where the pressure plate mounts get machined as well?
01-25-2023, 03:22 PM | #5 |
is it a multi disc clutch or was it updated to single disc
01-25-2023, 06:55 PM | #6 |
01-25-2023, 07:28 PM | #7 |
Had a friend have the same symptoms a few years ago with a newly rebuilt clutch. Finally found that the new clutch disk had a slightly raised area on one face about the diameter of a nickel. Had to look hard to find it. Changed out the disk and all was well.
Dave / Lincoln Nebraska |
01-26-2023, 02:32 PM | #8 |
It is commonly done to "surface" the flywheel/clutch surface, but not always necessary. Even "cracks" are tolerable provided the surface is not "scored" more than perhaps 0.005.
I would say wobble less than 0.002 you can ignore. I've now been through this three times - I have never had to address the friction surface. But I have been required to address a crankshaft flange issue. Joe K
Shudda kept the horse. |
01-26-2023, 05:50 PM | #9 |
does it only happen when you are using the clutch— moving the pedal?
or does it happen after the foot is off the clutch and car is moving? |
