01-24-2023, 02:02 PM | #1 |
e brake cross shaft
I had to remove the e brake cross shaft. The bearings were seized on the shaft. I finally got things loosened up and the arms off the ends. I cleaned up the shaft and arms, the bearings slide on smoothly and before I order new bearings, I decided to test mount everything. I now have about 3/4" end play in the cross shaft. I didn't notice this before because the bearings were seized to the shaft. Is this end play normal? This is a 1931 RPU.
Thank you Warren |
01-24-2023, 02:19 PM | #2 |
Re: e brake cross shaft
it is OK, when all the rods are hooked up, it will self-center.
01-24-2023, 03:49 PM | #3 |
I believe those are brass cup bushings, not bearings. Don't forget new felts. And yes, there is quite a bit of end play when everything is buttoned up.
JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
01-24-2023, 05:41 PM | #4 |
And it is "emergency." Your first couple of adjustments will probably result in it's permanent position in service - which will be repeated henceforth.
I might examine my frame for "bowing." My current project is at this point and the frame IS straight (I can see it) - but the E-shaft/cups/felts fit "snug" between the frame rails. Joe K
Shudda kept the horse. |
01-24-2023, 09:01 PM | #5 |
Are we talking about service or emergency brakes?
01-26-2023, 10:32 AM | #6 |
Warren |
