Old 06-06-2014, 12:59 PM   #1
oj
Default How were shifter handles made?
I just tried to reshape my '39 toploader handle, I used a tubing bender to make my first bend about 8" above where it goes into the transmission and the thing broke off! I looked at the break and there is a steel rod surrounded by mystery metal, the mystery metal is what makes the taper. It was my bad luck to bend right where they joined the pieces - at leats that is what it looks like.
Anybody comfirm this? Steel rods butted together, not welded and surrounded by dissimilar metal - looks almost like a cast metal.
My camera is broken or I'd post a picture.
I always thought the sticks were a 1pc forging.
oj is offline   Reply With Quote
Old 06-06-2014, 01:15 PM   #2
rich b
rich b's Avatar
Default Re: How were shifter handles made?
Strange lever you have there, I've heated and bent a bunch of levers and cut and welded others, never came across anything but solid steel. Some pictures would be interesting.
rich b is offline   Reply With Quote
Old 06-06-2014, 01:49 PM   #3
alchemy
alchemy's Avatar
I seen plenty of levers and have never come across anything like you describe. Just solid steel.
alchemy is offline   Reply With Quote
Old 06-06-2014, 02:02 PM   #4
AnthonyG
AnthonyG's Avatar
Yep should be all steel, solid. I put a '39 tranny in my '35 and had to rebend it to the '35 config. Used a conduit bender and a pattern to match up. Went well. I've seen them with the top cut off and new piece welded on and ground rto match and they even looked pretty good in case you find yours is steel weld a new top on it.
Nomad
AnthonyG is offline   Reply With Quote
Old 06-06-2014, 02:13 PM   #5
Mart
Mart's Avatar
Sounds like yours has been "got at" by a previous owner. I just bent and reshaped a 39 gear stick and it bent quite nicely cold.
Mart.
Old 06-06-2014, 02:21 PM   #6
oj
I wish I had my camera, if you look just above the top of the tranny the shaft is 1/2"ish until about 8" up where it gets large right in the sweep of the lower curve. That is the spot is broke cleanly - I was using a conduit bender - it didn't take much effort at all. The steel shaft looked like good Ford steel but the thicker part looked porous like broke cast iron.
The break was where the taper ends in the curve as it is going into the shifter tower.
Old 06-06-2014, 02:22 PM   #7
lonewolf
Re-production part?
lonewolf is offline   Reply With Quote
Old 06-07-2014, 05:23 AM   #8
Tim Ayers
What ever you have, doesn't sound stock.
Old 06-07-2014, 07:43 AM   #9
AnthonyG
AnthonyG's Avatar
I know few like ebay but there is a reasonable $65, 1939 shifter http://www.ebay.com/itm/1939-FORD-TR...f758dd&vxp=mtr
Nomad
Old 06-07-2014, 09:06 AM   #10
oj
No this was a Ford piece, all original. I bet it was broke and repaired, the 'casting' was an old old weld of somesort to join the 2 pieces.
How on earth do you break one of them? That is a serious chunk of steel. It ain't like somebody broke it hanging a heavy second gear in a race!
Old 06-07-2014, 10:55 AM   #11
AnthonyG
AnthonyG's Avatar
Out of curiosity was the top piece that broke off tapered to match the bottom piece? If so I cant imagine where who ever modified it would get a cast piece like that.Can you get a picture of it yet? I think someone either tried to weld and did a lousy weld or brazed it which would be a weak point.
Nomad
Old 06-07-2014, 01:07 PM   #12
oj
I wish I had a pic of it to share. I looked at the one on ebay and mine was different in that it came up out of the shift tower about 1/2", about 8" up it changed size to about 11/16ths and tapered to the shift knob. I thought they were all like that and the size change would fall at the top of the shift boot or something.
It was at the change in size that it broke.
I have shortened, rebent and welded it back together and now just finetuning the curves.
Old 06-07-2014, 03:20 PM   #13
AnthonyG
AnthonyG's Avatar
If the bottom half is the part that you know is solid steel and you have access to a lathe you could get a piece of round rod cold roll steel the dia. of the shifter bottom and match the taper then clean up the bottom half where you need to weld and weld them together then dress with file. Give your self a nice chamfer on top and bottom pcs for weld. I had a guy send me a tranny with stick cut in half to fit his box the tranny was in and I had to weld halfs together and blended with a couple of files and it looks great.
Nomad
Old 06-07-2014, 07:46 PM   #14
ford38v8
ford38v8's Avatar
About 8" up? Yep, that was my old shifter from my '39 Tudor. I cut it off and threaded it for my new handle, the reverse gear cutoff from a cluster and brassed in. My Dad did the brass and threading, I did the smoothing and sanding. Heavy bugger, made speed shifting easy as pie, just a flip of the wrist. Wish I had that Tudor today.
Alan
