10-28-2014, 04:36 PM | #1 |
replacement Square shaft for trunk handle
The shafts' threads have stripped on an original Model 'A' rumbleseat-cum-trunk handle assembly. I want to keep the original handle etc and replace just the square threaded shaft but all I find are complete aftermarket assemblies, I checked Brattons' and a couple others.
Any suggestions? |
10-28-2014, 04:55 PM | #2 |
Registered User
Re: replacement Square shaft for trunk handle
ive repaired them before
cut the shaft off where it will be easy to weld take a 3/8X24 bolt and cut to length now carefully and slowly mig or tig weld the shaft onto the cut off portion taking the neccisary steps to chamfer the edges first what you cant do is rush the welding as you will damage the lock cylinder and plating make a short weld then dip the lock portion in water to keep it cool don't put the shaft in the water keep going until the shaft is completely welded then using a file smooth out the weld,then slowly with a file file the shaft square to fit the lock assembly clean it up and your done you cannot run a die over the square shaft to make threads it will jamb every time tom |
10-28-2014, 04:59 PM | #3 |
Ron |
