Old 12-12-2023, 02:00 PM   #1
Smokedtires
Smokedtires's Avatar
Default Weird bolt in engine block
Anyone have any idea what this bolt hole is for? It's just forward of the oil fill tube.
Smokedtires is offline   Reply With Quote
Old 12-12-2023, 02:56 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Weird bolt in engine block
It may be a repair or a shade tree modification. It's not common.
Old 12-12-2023, 03:30 PM   #3
Ivan in southeast va.
Ivan in southeast va.'s Avatar
I don't have a bolt there on my engine. I agree with rotorwrench.
Ivan in southeast va. is offline   Reply With Quote
Old 12-12-2023, 03:58 PM   #4
mass A man
mass A man's Avatar
Possibly a bullet hole patch? Might be some JB Weld around it for any cracks under all the paint around the bolt patch? I've seen fairly clean bullet holes in old, abandoned sawmill engines out in the woods. It does appear a freeze crack has been repaired under water pump.
mass A man is offline   Reply With Quote
Old 12-12-2023, 05:01 PM   #5
WHN
How does the engine run?
More pictures?
Old 12-12-2023, 06:36 PM   #6
nkaminar
nkaminar's Avatar
Is there oil or water under it? When you remove it what do you find?
Old 12-12-2023, 07:02 PM   #7
Smokedtires
I did not remove it. Now that I just got the engine reinstalled, I started it tonight and it's running well. It was running good previously but I found babbitt in the oil when changed it so took a closer look, was likely over pour from when the mains were last done.
I haven't seen this in other A's but being new to the hobby I thought maybe I missed something with that there.
Old 12-12-2023, 08:52 PM   #8
ModelA29
ModelA29's Avatar
In the last shot it almost looks like there is a boss for the bolt cast into the block.
ModelA29 is offline   Reply With Quote
Old 12-12-2023, 10:58 PM   #9
johnneilson
Is this an “A” motor or a “B”?
Early B motors had a pad cast on the side of the block and two 3/8” bolt holes
The location would only have oil under it
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 12-12-2023, 11:24 PM   #10
lrf
I don't know either, but whatever you do, don't remove it cuz your car won't like that and will stop running!!! LRF
lrf is offline   Reply With Quote
Old 12-13-2023, 07:32 AM   #11
WHN
Remember your Mother telling you not to pick a scab?
Leave it alone and enjoy your well running engine.
Happy Holidays.
Old 12-13-2023, 08:18 AM   #12
Benson
Benson's Avatar
Bad dog benson ... bad dog! Not funny.
Old 12-13-2023, 08:51 AM   #13
Bob-A
Bob-A's Avatar
Smile Re: Weird bolt in engine block
Wow! I bet it is a one-of-a-kind Edsel Ford experimental motor that 'ol man Ford would not have approved....
Bob-A
"Skirts are for Women not Car Fenders"
Bob-A is offline   Reply With Quote
Old 12-13-2023, 10:31 AM   #14
jerrytocci
could be a tapped hole for a "non Ford " gen. bracket.
jerrytocci is offline   Reply With Quote
Old 12-13-2023, 10:39 AM   #15
jwmckenzie
I wonder if it was for some kind of rear support for the genny. My Jeep has this kind of an arrangement to support the back of the starter. Uses an "L" shaped bracket that bolts to the block and the back of the starter. Just a Wild Guess. Anything else about the block that would suggest it was from a stationary engine?
jwmckenzie is offline   Reply With Quote
Old 12-13-2023, 10:39 AM   #16
jwmckenzie
My thought exactly
Old 12-13-2023, 08:08 PM   #17
GeneBob
You have a 1 in 5,000,000+ engine there!
You know, with the right marketing, every Model A owner will want to order one of those "speed bolts" for only $4.95 + shipping!
GeneBob is offline   Reply With Quote
Old 12-14-2023, 08:27 AM   #18
Smokedtires
Hahaha, I will leave my unicorn bolt be. Thanks all!
Old 12-14-2023, 08:35 AM   #19
Joe K
Joe K's Avatar
Early attempt at a PCV valve?
Joe K
Shudda kept the horse.
Old 12-18-2023, 02:01 PM   #20
David in San Antonio
David in San Antonio's Avatar
I found an original unopened NOS box of these bolts but not the stock ones. These are special high-strength lightweight alloy racing type. You can definitely feel the difference particularly going uphill, downhill, and on flat ground. Most knowledgeable people optimize the performance advantage by switching to lightweight water for the cooling system, too.
1930 ('31?) Deluxe "Wretched Roadster"
Restored 1957
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
