Old 03-01-2021, 10:45 AM   #1
jason78613
jason78613's Avatar
Default Which fuel fittings?
The connection from the copper fuel line to the newly installed gas tank in my '38 Ford standard has a small drip no matter how much I try to tighten it. I'm thinking the old fitting is no longer good?
I'm guessing it's the 2 piece with nut and ferrule, but want to make sure I order the correct one...Which of these two fittings is correct, and what are the different uses between the two?
https://cwmoss.com/products/fuel-lin...-piece-1932-48
https://cwmoss.com/products/fuel-lin...-piece-1928-29
jason78613 is offline   Reply With Quote
Old 03-01-2021, 10:58 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Which fuel fittings?
Why don't you just remove the leaking fitting to see what you have instead of relying on someone else's guess.
Old 03-01-2021, 11:43 AM   #3
Will D
Will D's Avatar
Either one will work. In my experience, if you are installing it and leaving alone, the one piece is good. If you take it on and off a few times, the 2 piece will hold up better and the ferrule can be changed easily while reusing the nut.
Either fitting will leak if over tightened, keep that in mind.
Sometimes, ingenuity gets in the way of sense and sanity.
Will D is offline   Reply With Quote
Old 03-01-2021, 12:04 PM   #4
jason78613
jason78613's Avatar
Fair point, but I'd like to have the fitting in hand before starting the job of draining the tank and and removing the old connection. I guess I can just order them both! :-)
Old 03-01-2021, 12:06 PM   #5
34PKUP
34PKUP's Avatar
Did you ever easily remove a ferrule that has been firmly swaged on to a steel tube?
34PKUP is offline   Reply With Quote
Old 03-01-2021, 12:14 PM   #6
1948F-1Pickup
1948F-1Pickup's Avatar
^ That is a good point. Far more standard practice to chop it off and
use a new olive.
1948F-1Pickup is offline   Reply With Quote
Old 03-01-2021, 12:14 PM   #7
Mart
Mart's Avatar
I prefer the two piece design. I have successfully removed the ferrule from a one piece and used with an ferrule from a one piece. Often there is enough slack in the length of a pipe that it can be shortened the amount needed to use it with a new ferrule.
Mart.
Old 03-01-2021, 12:47 PM   #8
Will D
Will D's Avatar
Don't over tighten. At the point your thinking of, cut the line or get a new one. Makes do difference if one or two piece then....
Old 03-01-2021, 03:18 PM   #9
Pete
Pete's Avatar
Change to STEEL fuel line like original and the problems will go away.
In some places, copper fuel and brake lines are illegal and insurance companies definitely don't like them.
