Old 04-11-2016, 03:51 PM   #1
MII
MII's Avatar
Smile rear end
on my 37 rear end there the numbers stamped where I understand the gear ratios would be and it is 1 39 and a inch or two away is stamped 2 and that is all how can you tell the ratio from this?
MII is offline   Reply With Quote
Old 04-11-2016, 04:12 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: rear end
If it is actually an 11-39, it would indicate it originally had that wonderful 3.54 ratio that everyone wants. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-11-2016, 05:10 PM   #3
MII
MII's Avatar
thank you DD I will go with that
Old 04-11-2016, 05:16 PM   #4
JSeery
JSeery's Avatar
Might be worth checking. There are several ways to go about it.
Old 04-11-2016, 06:21 PM   #5
Old Henry
Old Henry's Avatar
Oops. I saw the heading and just had to post.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 04-11-2016, 07:32 PM   #6
ford38v8
ford38v8's Avatar
Henry... Kiss me, you fool.
Alan
Old 04-12-2016, 08:23 AM   #7
Ford Freak
I'd like to check mine . Please explain how .
Ford Freak is offline   Reply With Quote
Old 04-12-2016, 08:02 PM   #8
38 coupe
38 coupe's Avatar
On most banjo housing the ring and pinion tooth counts were stamped at the factory on the bottom rib. You divide the bigger number by the smaller number. In the example above 39 divided by 11 equals 3.54. Common numbers are 9 with 34 which is a 3.78 and 9 with 37 which is 4.11.
Old 04-12-2016, 08:42 PM   #9
JSeery
JSeery's Avatar
I was referred to physically checking the ratio. You can jack one wheel up and count tire rotations (which I would have to look up because I have never done it). Or remove the fill plug and mark a tooth on the ring gear and then slowly turn the gear and count the teeth.
Note: Here is the link - http://www.btc-bci.com/~billben/reargear.htm
