03-22-2020, 09:34 AM | #21 |
Re: Engine repaint
All great ideas. My repaint won’t be as hard as I had engine apart w heads, oil pan, distributor, carb’s, headers, & starter off. Premasked heads & intake on the bench & set on engine w a couple bolts each effectively using them as masking for the block. Seemed easier anyway! Left only the exhaust & distributor holes to mask on block.
Nomad |
03-22-2020, 09:48 AM | #22 |
Re: Engine repaint
Hope you plan on stripping the old yellow paint off. Any chip in the new darker paint and the yellow underneath would stick out like a sore thumb.
03-22-2020, 10:25 AM | #23 |
Re: Engine repaint
38bill, I admire ur energy fortitude😁! I don’t have that much left @ 70😂! I’ve removed loose paint w wire wheel / drill motor & cleaned w brake cleaner & will wipe w paint thinner. Also will do at least three coats of durable engine paint. After that I’ll live w it & call it Patina😂. If I didn’t have to remove the engine for the work I had to do it wouldn’t have even gotten any new paint
Nomad |
03-22-2020, 07:42 PM | #24 |
Re: Engine repaint
POR make engine paint "Ford green" which you can brush on, you'd never know on the cast block but the pan you may have a few streaks of that worries you, probably depending on the brush etc .
03-22-2020, 08:08 PM | #25 |
Re: Engine repaint
That engine looks great, but the green seems a little, ehh, light.
03-22-2020, 09:37 PM | #26 |
Re: Engine repaint
Hirsch to me is a bit light, but very very good. Roy had a good match for early ford. https://www.fordbarn.com/forum/showthread.php?t=195644 Non-ford. I've seen one a flake copper tangerine. Yes I wouldn't like to clean that motor. Color can be subjective if doing your own thing. I'm not a big red or yellow guy mostly. It really depends on what you want. Last edited by Tinker; 03-22-2020 at 10:08 PM. |
03-22-2020, 11:03 PM | #27 |
Re: Engine repaint
Cant remember but its probably the flash, its a little darker than that.
03-23-2020, 06:53 AM | #28 |
Re: Engine repaint
I think Talkwrench,, that your color looks more like 50 Mercury green ?? Looks like a friends 50 Merc to me. 02 cents, or nonsense.....
It will look GR8 put together, it's a FLATHEAD !!!! |
03-23-2020, 08:16 AM | #29 |
Re: Engine repaint
^^ THat's what I thought, too.^^
03-23-2020, 08:24 AM | #30 |
Re: Engine repaint
I have a black painted engine. Gloss black. it isn't great for spotting oil leaks and water leaks.
Looks ok though. Here in the UK Hammerite do a smoothrite gloss green which looks ok on the old flattys. |
03-24-2020, 04:00 PM | #31 | |
Re: Engine repaint
I use start fluid for a quick clean up. However, respectfully, you need to know that some start fluids contain a cylinder lubricant. So when getting ready for paint I rely on a prep solvent designed to degrease. Always a winner.
Enjoy yer day. Tom Hate can't fix what it started. |
03-24-2020, 09:32 PM | #32 |
Re: Engine repaint
Acetone is cheap. dries quick.
03-28-2020, 12:58 PM | #33 |
Re: Engine repaint
018EE808-63DC-4B94-ABEC-24010A132AF1.jpgThinking looks pretty good even though my masking skills r in question gotta get a bottle of touch up for my imperfect masking
Nomad |
