02-24-2020, 05:33 PM | #41 |
Re: Installing replacement pistons
I have some 59a numbers, I don't mess with 8ba. From the Repair Manual Ford, Mercury & Truck V8 Engines 1937 to 1947 these are maximum ware limits.
Bore out of round .003 Bore taper .006 Piston to cylinder 6-10 lb pull .005 w/.5 feeler gauge Rod bearings .005 Piston ring end gap .035 Last edited by JSeery; 02-24-2020 at 05:43 PM. |
02-24-2020, 05:40 PM | #42 |
02-24-2020, 08:06 PM | #43 |
You'll want the green and you'll want around 1 to 2 thou clearance.
02-24-2020, 08:35 PM | #44 |
On the rods, I like to have about .015 to .002 or so - more on a race engine. On the mains, about .002 to .0025.
What type of rod bearings are you running - full-floaters or late style (49-53) tanged bearings? It is really hard to use Plastigauge with floaters - these types of bearings need to be "fitted" to the rods and crank - I can't see PlastiGauge being of much value to the full-floater process. Also, since you need clearances on BOTH sides of the full-floater bearings, plastigauge really can't tell you enough. |
02-24-2020, 10:34 PM | #45 |
Tanged type. Read an article on crank mains & rod bearing clearance. It was interesting. Indicated best rule of thumb is, .00075”-.001 per inch of diameter of journal is a good gauge! Then adjust for more oil pressure lean to .00075” for more HP lean more to .001”. Made sense. As my 8BA has the Merc 4” stroke crank, a 3/4” isky cam, Domed forged pistons & oversized valves I think I’ll do the .001 per in of diameter. So 2.1185 journal X .001=.0021185 or rounded .002” which is within range of what Flatjack9 & Bored&Stroked indicate.
Thx for the help guys!!
Nomad |
03-01-2020, 07:49 PM | #46 |
Nomad |
03-01-2020, 09:37 PM | #47 |
03-01-2020, 10:43 PM | #48 |
Just refitted new pistons, went w new rod bearings. Rods bearing races were line honed. With only 2000 miles on since rebuild original honing cross hatch still visible & could feel in cylinders with finger nail, was obvious engine hadn’t broken in yet. No ridge line either. Advise from several on FB & original builder was the risk of honing greater than the reward on this new an engine.
Nomad |
