08-16-2019, 01:19 PM | #1 |
Anyone use a TomTom gps?
Anyone use one & it's so, how do u convert it to 6 volt? I don't want to use my phone cause it'll eat up my minutes
Thanks Dick |
08-16-2019, 01:48 PM | #2 |
Re: Anyone use a TomTom gps?
There is another thread on GPS charging. Last updated this morning.
Says that the regulator is in the plug. I use my phone and GPS on 6volts. |
08-16-2019, 01:56 PM | #3 |
I use a Garmin navigator and have a small 12 volt battery 9Ah Rechargeable Sealed Lead Acid AGM Battery under the front seat. I connect to the battery with a Car Accessory female Cigarette Lighter Socket cord that lies on the seat. I connect to the battery using a Car Accessory male Cigarette Lighter plug. And I charge the battery using a Car Accessory male Cigarette Lighter plug.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
08-16-2019, 06:17 PM | #4 |
I have a garmin and use a small cell phone/tablet charger. Works great. Rechargeable.
https://www.amazon.com/Anker-PowerCore |
08-16-2019, 07:18 PM | #5 | |
David Serrano |
08-16-2019, 07:32 PM | #6 | |
08-16-2019, 07:47 PM | #7 |
I don’t know about Tom Toms but Germans run on 5 volts. The adapter will cut the volts down from 12 or 6 down to 5. Assuming you have a standard Model A with positive ground you have to be careful about the polarity. Reverse the wires + to - and - to +. If your adapter case has metal around it be careful because now it is hot and will short to ground. Just insulate it somehow with tape or something non conductive.
08-16-2019, 09:29 PM | #8 |
08-17-2019, 07:22 AM | #9 |
With 6 volts positive ground...Remember polarity when hooking up a plug... Chap
08-17-2019, 08:11 AM | #10 |
08-17-2019, 11:02 PM | #11 |
If I did this right you should have an attachment. I did this and it works great for my GPS/Cell Phone
08-18-2019, 04:11 AM | #12 |
Put the Waze app on your phone. This will do everything, speed,traffic, places of interest.
GPS devices are a thing of the past. |
08-18-2019, 04:49 AM | #13 |
Does Waze always work out of phone range? I can nearly always get a GPS signal , but using a phone app is uncertain in some patches because of areas of poor phone coverage
08-18-2019, 09:54 AM | #14 |
I don't mean to hijack the thread but does anyone make one of these units that will jump/charge 6 volt and 12 volt cars?
08-18-2019, 10:08 AM | #15 | |
The Model A Ford is a thing of the past!!
08-19-2019, 07:55 AM | #16 | |
This is for Android : http://backcountrynavigator.com/android-gps/ Cheers |
08-19-2019, 08:29 AM | #17 |
I'd like to know how people connect devices to the ignition switch to turn it on and off. The ignition switch only connects the coil to the points and does not provide a way of turning on or off anything. Jack
08-20-2019, 09:33 AM | #18 |
Tap into the ignition switch existing wiring, or some venders offer an ignition switch with a spare wiring contact/connection.
Thread Tools | |
Display Modes | |
