08-04-2017, 06:56 PM | #1 |
Completed '48 F-1 front sway bar
Had it bent by a company in North Carolina, 1 1/8" diameter and fabbed the rest of the pieces myself. Rod ends and sliding blocks to adjust the ends.
She's flat in corners now! (sorry- no lift, otherwise I'd have a better photo) |
08-04-2017, 09:26 PM | #2 |
Re: Completed '48 F-1 front sway bar
Nice!
08-04-2017, 10:01 PM | #3 |
Thanks. It was one of those measure 5 times
type of jobs. Glad it's done. |
08-05-2017, 08:21 AM | #4 |
Looks good. Did you add a reinforcement to the inside of the frame where the bushings clamp mount?
08-05-2017, 08:45 AM | #5 |
Here's a neat sway bar torsional stiffness calculator. Plus, did you know that sway bars can be hollow.
http://www.gtsparkplugs.com/Sway-Bar-Calculator.html |
08-05-2017, 09:38 AM | #6 |
08-05-2017, 11:06 AM | #7 | ||
drilled out the factory rivet in the frame. That's where there's a fairly hefty cross-member tying everything together. The bolt replacing the factory rivet is 7/16" and the rear bolt location for the sway bar bracket is around 2" back. Shouldn't be an issue. Quote:
and cost made me search out a place that could bend a standard bar. I had forgotten about that particular website.... I used Puhn's equation when I was doing the calcs. My initial gut feeling was about 400#/in would be just about right and I could slide the ends in if I wanted stiffer. The 1 1/8 bar landed at right around 450#/in, so it worked out well. Last edited by 1948F-1Pickup; 08-05-2017 at 11:19 AM. |
08-05-2017, 11:23 AM | #8 |
08-05-2017, 12:20 PM | #9 |
Go with the black.
Gold is a bit gaudy. |
08-06-2017, 12:26 AM | #10 |
Beautiful job! Any plans for making a few to sale?
53 F100, 8CM flathead ------------------------------- |
08-06-2017, 12:01 PM | #11 |
I didn't have any plans but it could be done.
The sliding adjusters on the bar ends are a real "treat" to make. (very labor intensive) At around $600, a one-off is definitely not happening. A project like this would have to be done in quantities of 10 to bring the bar itself ($300 for mine) into some concept of economy & marketability. Hellwig and a few others minimums are 10 units...... That's how it would have to be done. |
