Old 01-16-2021, 10:39 PM   #1
barnnone51
Default Mount Wind Screen
How to you mount the windscreen? I see to holes at the top nothing there to anchor to. Can someone give me some direction how to attach.
barnnone51 is offline   Reply With Quote
Old 01-17-2021, 08:45 AM   #2
fundytides
fundytides's Avatar
Default Re: Mount Wind Screen
Need more info. What year? Do you have the stanchions? Looks like the pivot stud that mounts to the stanchion is broken off in the frame. It screws into the frame.
fundytides is offline   Reply With Quote
Old 01-17-2021, 09:00 AM   #3
barnnone51
Yes I have the stanchions. So should there be some type of nut attached to the windshield? Only holes there. I have these studs which I believe are correct. The Roadster is 1930. Would sure like a pic of a correct mounting. Thanks for your help.
Old 01-17-2021, 09:04 AM   #4
barnnone51
Old 01-17-2021, 10:29 AM   #5
fundytides
fundytides's Avatar
Ken, just going by memory but I think there should be a threaded hole for the short end of the stud to thread into. If this doesn't make sense let me know and I will take a stanchion off and look.
Old 01-17-2021, 11:24 AM   #6
Bob C
You also need this part.
Old 01-17-2021, 06:11 PM   #7
barnnone51
Thanks Ya"ll for the info. Took the frame apart and found the flat bar with the threads. so Back in business. Thanks Again.windshield stud.jpg
Old 01-17-2021, 06:16 PM   #8
barnnone51
