anyone ever run a 4100 carb on a flathead?
I'm sure it would work well, but would need an adaptor to fit on the small 4 barrel pattern on flathead intakes. They were made in a few different sizes from about 400 to 600 CFM.
Sal |
Haven't run a 4100 on a flathead but you'd use a Navarro or Offy or other purpose built 4-bbl manifold.
From Autolite the 4100's range from around a 1" venturi to a 1.19.... a bit over 300 cfm to about 600 cfm at the other extreme. The SAE standard would be to flow automotive stuff at inches of mercury, Autolite may have done it at inches of water because the 4100 numbers aren't quite as impressive as Holley's. Here's an experimental "blower" 4100 with 1.23 venturis- |
When I had an old 64 T-bird, I had problems with the vacuum diaphragm that operated the secondary throttle plates. I ran the car mostly on the primaries due to that. I replaced that diaphragm multiple times and they just didn't want to last. Maybe I was too heavy on the throttle or the parts were just crap I don't know.
You just needed one of these nifty vacuum secondary override kits.....
#7 | |
![]() Quote:
Sal |
Has been working just fine since 1981, but then again I don't try to
open all 4 bores at 15 mph.... |
It would take some venturi vacuum to open the secondaries. It always takes a bit to get enough flow from the primaries to get the secondaries to open up. My problem wasn't that the diaphragm would be damaged by a back fire. It's that the way the diaphragm is made, it just has slots to clear the retainer screws that hold it in place. It eventually just pulls the diaphragm into the chamber. Holley's design for vacuum secondaries is better. I'd get on the old bird to pass someone but it was no drag racer off the line. I think a person would be better served by two 2100s with a progressive linkage or simply use a Holley 4V instead. Ford used the Holley for performance applications for a reason.
I don't think those Eelco kits are available anymore. Last edited by rotorwrench; 11-30-2020 at 02:02 PM. |
