06-16-2020, 06:46 PM | #1 |
Reds Headers. Washers?
Hi Fordbarn,
I just got a set of Reds Headers for my 39 Sedan and it came with a bolt kit but no washers. What are your thoughts? Should I pick up a set of lock washers? Locktite? Just use the bolts as is? Thanks for your input. Chris |
06-16-2020, 10:42 PM | #2 |
Re: Reds Headers. Washers?
I use flat washers and antiseize compound. I am afraid the lockwashers will
crack and break due to expansion and contraction and loose their effectiveness. No Loctite. |
06-17-2020, 09:35 AM | #3 |
I did the same. Use a good grade washer and hi temp anti-seize. Check torque every 6 months or so.
06-17-2020, 03:09 PM | #4 |
