Old 03-07-2020, 03:23 PM   #41
AnthonyG
AnthonyG's Avatar
Default Re: Install oil filter
Putting engine back together. I found/bought an original bypass filter canister set up. Good shape w the original pressure sender & the .060” reducer still on it. I couldn’t believe the guy shipped it so dirty & still filled w gunky oil & an old filter in it! Anyway need the to-from lines & found these on EBay. Says fits a ‘49-‘53 F1 but thinking it’ll fit my 8BA? Thoughts?
File Type: jpg 65C666FD-5682-4843-95E2-D516D6B6C1BE.jpg (6.0 KB, 77 views)
Nomad
AnthonyG is offline   Reply With Quote
Old 03-07-2020, 03:23 PM   #42
AnthonyG
AnthonyG's Avatar
Sorry, forgot the picture of the lines
Nomad
Old 03-07-2020, 05:20 PM   #43
tubman
tubman's Avatar
I would expect them to fit fine. I have never used those exact lines, but I have mixed and matched many parts between car & truck engines, and with the exception of the water pumps and belts never had any problem. If those fit I would use them, because fitting regular off the shelf lines would probably require cutting and double flaring, which isn't the most fun thing in the world. Plus, I find bending them just right to be a real pain (in the fingers) as well.
Old 03-07-2020, 06:35 PM   #44
AnthonyG
AnthonyG's Avatar
Thx Denny, I ordered.
Nomad
Old 03-08-2020, 10:58 AM   #45
19Fordy
19Fordy's Avatar
Anthony : You can make your own lines using 1/4 inch brake line tubing. Make steel connectors by drilling out the shanks of some 3/8 dia. bolts and soldering them to the lines as needed. You can see them in the photos. Also couplers are used to join male ends of fuel line.
Old 03-08-2020, 01:19 PM   #46
Aarongriffey
I neglect changing my oil filter on my 8RT a lot. That’s a big reason to use AMSOIL.
Even if you think the original filter set up is better, the spin on filter is more likely to keep the oil cleaner because it is less apt to be neglected.
Hey 51 merc, You left your lights on!
Aarongriffey is offline   Reply With Quote
Old 03-08-2020, 01:24 PM   #47
tubman
tubman's Avatar
How can you forget a filter that's right up there in your face everytime you check the oil? I would think it would be a lot easier to forget a full flow filter, especially if it's mounted remotely down in some dark abyss.
You are correct (in my opinion) when you say "the original filter set up is better".
Old 03-08-2020, 01:42 PM   #48
flatheadmurre
flatheadmurre's Avatar
The lines a std 1/4 brakelines and fittings...i just flare them the size i need for my aplication.
No need to make any special hardware.
The optimum filter setup would be a fullflow directly from pump and keeping the bypass for fine fitration...but who wants all that plumbing
Old 03-08-2020, 03:38 PM   #49
JSeery
JSeery's Avatar
Curious on stationary engines, how did they keep track of oil changes? Hour meters? On some aircraft the is an hour meter that operates when oil pressure is present.
Old 03-11-2020, 09:53 AM   #50
AnthonyG
AnthonyG's Avatar
Nicely don 19Fordy!
Nomad
Old 03-11-2020, 02:19 PM   #51
19Fordy
19Fordy's Avatar
Thanks Anthony. One last thought. In order to make it easier to install the oil lines put your oil filter canister into position but, don't tighten it down until AFTER you install all the other oil line connections. Makes it easier for the threads on the fittings to "catch".
Old 03-11-2020, 06:31 PM   #52
AnthonyG
AnthonyG's Avatar
Good advise! Thx for all the great info. I’ll post a pick when complete. I’m having the original equipment Canister I found powder coated black gloss. I have a repro of one of the original decals used on the canister. Should look great & will b happy to have a working filter!
Nomad
Old 03-11-2020, 07:40 PM   #53
tubman
tubman's Avatar
If the engine is really an 8BA, it is from a car, not a truck, and the oil filter canister should be bronze, like the rest of the engine. An exception would be an early '49, which I believe is blue. Gloss black will certainly look nice, but I thought I'd mention this. (I don't remember the kind of vehicle this will end up in.)
Old 03-16-2020, 06:45 PM   #54
AnthonyG
AnthonyG's Avatar
My ‘35, went w an 8BA mainly for the removable bell but also cause lots of enthusiasts like them. Kind of emulated the original ‘35 Engine by building the front of the engine like an 59A w a crab style front center distributor. Hind sight is 20/20 & wish I’d of gone w verticle distributor mounted higher.
File Type: jpg 748289CE-2EF2-4F5D-894F-75362255AA60.jpg (103.8 KB, 16 views)
Nomad
Old 04-12-2021, 05:35 PM   #55
AnthonyG
AnthonyG's Avatar
Bypass oil filter installed. Thx for all the tips & advice here’s a pic.
File Type: jpg C670EFE6-32E7-49C9-9D2C-D7C89BBFC7F1.jpg (61.2 KB, 48 views)
Nomad
