01-14-2020, 02:46 PM | #1 |
New gasket for 1930 radiator cap question....
I removed the original gasket from my repro cap and my new gasket 'floats' in the cap between the copper 'gasket' and twist clamp.
Original gasket was larger and was a snug fit as it was installed during production. New gasket has a larger center hole so it will fit over twist clamp and is loose. Should I adhere the new gasket with a sealer or leave as is? Thank you from Bullhead City |
01-14-2020, 03:38 PM | #2 |
Re: New gasket for 1930 radiator cap question....
Id say no sealer!
www.whidbeymodelaclub.com |
01-14-2020, 05:03 PM | #3 |
As long as it won't fall off don't worry about it.
01-14-2020, 06:32 PM | #4 |
Thank you both for your replies.
No sealant 'it is'. |
01-15-2020, 06:46 PM | #5 |
