Old 12-18-2010, 03:25 PM   #1
brentom
Default 1949 Mercury flathead water pump
it appears I have antifreeze leaking from the drivers side, I assume it is the water pump, my questions are:
1. Is Ford and Mercury water pumps the same?
2. Do I rebuild or buy new?
Thanks,
Tom
brentom is offline   Reply With Quote
Old 12-18-2010, 03:55 PM   #2
Charlie ny
Default Re: 1949 Mercury flathead water pump
Bren,
Merc pumps are different from Ford where they mount to the chassis. I believe
there are at least 2 different styles. Someone on the Barn will know where you can get
a pump. In my area I rebuild them for local customers. I can tell you they don't
come apart as easy as the '37 - '48 style pump.
Charlie ny
Old 12-18-2010, 04:14 PM   #3
brentom
Originally Posted by Charlie ny View Post
Bren,
Charlie ny
thanks Charlie
Old 12-18-2010, 04:19 PM   #4
Old Henry
Old Henry's Avatar
Don't know much about rebuilding but if you want one rebuilt ready to go here are some from C&G for $190.00: https://secure435.hostgator.com/~dlv...&g=97&t=712&tn=
Or, you can have yours rebuilt with higher velocity impellers by Skip Haney for $200.00 here: http://www.fordcollector.com/water_pumps.htm
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end. *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 12-18-2010, 04:19 PM   #5
V8 Bob
V8 Bob's Avatar
Here are some pictures of the Ford and Merc pumps. The '49-'51 Merc pump bodies are basically the same except the '49 Merc had wide belt pulleys, while '50-'51s used narrow belts.
I don't have any '49 Ford car pumps to show (same as '53 trucks) but they are the same as the '50-'53 except for wide belt pulleys.
Old 12-18-2010, 04:40 PM   #6
Charlie ny
Bren,
What Old Henry says....$200 is mucho reasonable especially
if you get 'George Mitchell' impellers....Skip is the way I'd go for sure.
Charlie ny
Old 12-18-2010, 05:34 PM   #7
rotorwrench
rotorwrench's Avatar
I made a tool out of an old impeller to press the seal in to the correct dimensions. There are rebuild instructions on the flathead techno-source site titled "49 - 53 waterpump rebuild by Dave O'Neil". http://www.btc-bci.com/~billben/flathead.htm They are a pain to rebuild but the kits are around 25 bucks if you have the tools & equipment to do the job.
Kerby
